Wfserver and rigctld/virtual serial port
Hi Team,
I cannot find info is there any possibility like in normal wfview operation run rigctld or prepare virtual serial port for additional software like PAT or direwolf ?
Thank You for suggestions where to dig in.
Piotr SQ9FK
Yes, please see our manual, both topics are covered under “Sharing Control”.
You mentioned wfserver, sorry, if you are running the pure server command-line version, then I’m pretty sure we do not offer support for the virtual serial port and rigctld.
You can, of course, run the regular wfview on the command-line. And this could be all you need to do for what you’re trying.
wfview -platform offscreen
We haven’t tested this mode of operation much though!
OK from 1st shot it start. I will check this.
But what I discovered. In previous 2.01 Power ON works with wfserver + wfview 2.01. Now I cannot turn on radio. With only wfvierw 2.03 Power ON works. So probably something is wrong in latest wfserver.
Power OFF works.
SQ9FK
Power on/off is somewhat tricky.
What radio model?
Icom 7300
Power ON - not working
SQ9FK
