I am just beginning to look into running wfserver on an RPi3B. So far I have successfully done the following:
- Operated WFVIEW from my windows laptop connected directly to the IC-7300
- Operated a client WFVIEW from my windows laptop connecting to a WFVIEW server on the RPi. (I even have sound from both a USB headset and the built-inn speaker, although it is sometimes choppy.)
- I built WFSERVER following the online instructions.
- Ran “wfserver --debug &” on the RPi and I am not seeing my laptop client successfully operating the radio. However the client does not complain, and it shows the “Cancel Connection” button as if the client was able to make a successful connection to the server.
Here is where I am:
The client (wfview) side log file:
wfview-20241107104648.log (2.3 KB)
The server .conf file:
wfserver.conf (594 Bytes)
I don’t know where the server-side log file is located. I don’t see it in the same folder where wfview puts its log files.
My first question is where should the wfserver log files be found? If someone can spot any other problems in the two uploaded files, that would be helpful.
Jim, AK6JS
