Wfserver updated?
Are there any plans to develop upgrade wfserver ?
Opus is not supported.
Piotr SQ9FK
wfserver is updated since our 1.64 release, yes. And there are plans to update it more!
Opus is, was and will be supported. You just need to select it from the client side so that the connection is encoded with Opus.
2025-01-01 23:37:19.728 INF udp: udpHandler : Detected connection speed
2025-01-01 23:37:19.728 INF rig: Error using port “UDP” message: “Opus codec not supported, forcing LPCM16”
2025-01-01 23:37:19.728 INF rig: Error using port “192.168.6.3” message: “Invalid Username/Password”
2025-01-01 23:37:19.728 INF system: wfmain: received error for device: “UDP” with message: “Opus codec not supported, forcing LPCM16”
2025-01-01 23:37:19.729 INF udp: Closing UDP stream : “192.168.6.3” : 50001
It’s from Log.
Piotr SQ9FK
I just noticed it don’t takes -s or --setting conf file.
I define /dev/ttyIC7300 symlink but he takes one from ttyUSBx (0).
The same by sound card. Could You verify this separetly from my side ?
SQ9FK
Hi Piotr,
In your opus question, to be clear, you are running an IC-7300 on the computer with the server (wfserver) and you are connecting to it from another computer running wfview, and you are selecting Opus as the connection codec on the client side, and receiving this error message, yes?
If so then we have not handled this properly, sorry :). It is supposed to work. You can probably run the GUI wfview server for now if you need it.
As for the serial port, I believe this is the field to write (@phil can correct me though if I’ve got this wrong):
[Radios]
1\SerialPortRadio=/dev/IC7300
This is the important part of your log!
Try with a valid username and password and you will get this:
2025-01-01 23:02:03.244 INF udp: udpHandler : Detected connection speed WFVIEW
2025-01-01 23:02:03.245 INF udp: udpHandler "Received radio capabilities, Name: IC-7300_03012570, Audio: ICOM_VAUDIO, CIV: 00, MAC: 00:90:c7:34:35:3a CAPF: 5001"
2025-01-01 23:02:03.246 INF udp: Got Connection status for: IC-7300_03012570 Busy: 0 Computer IP "0.0.0.0"
2025-01-01 23:02:03.246 INF udp: Got Radio 0
2025-01-01 23:02:03.246 INF udp: Find available local ports
2025-01-01 23:02:03.247 INF default: Received serial port baud rate from remote server: 115200
2025-01-01 23:02:03.248 INF default: Changing queue interval to 100 ms
2025-01-01 23:02:03.248 INF system: Delay command interval timing: 100 ms
2025-01-01 23:02:03.248 INF udp: Starting udpCivData
2025-01-01 23:02:03.249 INF udp: UDP Stream bound to local port: 50506 remote port: 50002
2025-01-01 23:02:03.249 INF udp: Starting udpAudio
2025-01-01 23:02:03.250 INF udp: UDP Stream bound to local port: 50507 remote port: 50003
2025-01-01 23:02:03.252 INF udp: udpHandler Got serial and audio request success, device name: "IC-7300_03012570"
2025-01-01 23:02:03.252 INF udp: Got Connection status for: IC-7300_03012570 Busy: 1 Computer IP "127.0.0.1"
2025-01-01 23:02:03.256 INF audio: Output audio handler starting: "Speakers (Intel® Smart Sound Technology (Intel® SST))"
2025-01-01 23:02:03.256 INF udp: udpCivData : Received I am here
2025-01-01 23:02:03.257 INF audio: Input audio handler starting: "Microphone Array (Intel® Smart Sound Technology (Intel® SST))"
2025-01-01 23:02:03.257 INF audio: Output thread id 0x70d0
2025-01-01 23:02:03.257 INF audio: Output start() running
2025-01-01 23:02:03.258 INF udp: udpAudio : Received I am here
2025-01-01 23:02:03.258 INF audio: Input thread id 0x4338
2025-01-01 23:02:03.258 INF audio: Input start() running
2025-01-01 23:02:03.260 INF audioconverter: Starting audioConverter() Input: 1 Channels of 2 48000 Float Output: 2 Channels of 0 48000 Float
2025-01-01 23:02:03.261 INF audioconverter: Starting audioConverter() Input: 2 Channels of 0 48000 Float Output: 1 Channels of 2 48000 Float
2025-01-01 23:02:03.261 INF audioconverter: Creating opus decoder: success
2025-01-01 23:02:03.261 INF audioconverter: Creating opus encoder: success
Ha! Can’t believe I missed that!
Yes but Phil even when I copy hash from working wfview.conf → wfserver not taking conf file into consider. I’m sure about correct paths. Using the same in previous command for nano to edit it.
Piotr SQ9FK
Hi Piotr,
Can you please show us the entire command line used to launch wfserver as well as a log? It seems we need to confirm the settings file is used and that the login is ok. Then opus.
I would make sure that the password doesn’t contain any ‘special’ characters. The Icom protocol only supports a very limited number of non-alphanumeric characters, so I find it easier to limit passwords to these.
Ok, so I attach config file:
wfserver.conf (423 Bytes)
Command:
Zrzut ekranu 2025-01-02 103222
Log:
sq9fk@sq9fk-pi4:~ $ wfserver -d -s .config/wfview/wfserver.conf
2025-01-02 10:33:33.865 “wfserver version: 1.91 (Git:18a556f on Dec 30 2024 at 08:00:43 by sq9fk@sq9fk-pi4)\nOperating System: Debian GNU/Linux 12 (bookworm) (arm64)\nBuild Qt Version 5.15.8. Current Qt Version: 5.15.8\n”
2025-01-02 10:33:33.866 Returning instance of cachingQueue() to calling process: “”
2025-01-02 10:33:33.867 Starting caching queue handler thread (ThreadId: 0x7f9ba16000 )
2025-01-02 10:33:33.871 “Found Rig DEFAULT with CI-V address of 0”
2025-01-02 10:33:33.877 “Found Rig IC-705 with CI-V address of 164”
2025-01-02 10:33:33.880 “Found Rig IC-706 (Mk1/Mk2) with CI-V address of 72”
2025-01-02 10:33:33.883 “Found Rig IC-706 (MkIIG) with CI-V address of 88”
2025-01-02 10:33:33.886 “Found Rig IC-7100 with CI-V address of 136”
2025-01-02 10:33:33.889 “Found Rig IC-718 with CI-V address of 94”
2025-01-02 10:33:33.892 “Found Rig IC-7200 with CI-V address of 118”
2025-01-02 10:33:33.896 “Found Rig IC-7300 with CI-V address of 148”
2025-01-02 10:33:33.900 “Found Rig IC-746 with CI-V address of 86”
2025-01-02 10:33:33.903 “Found Rig IC-746 PRO with CI-V address of 102”
2025-01-02 10:33:33.906 “Found Rig IC-756 with CI-V address of 80”
2025-01-02 10:33:33.910 “Found Rig IC-756 PRO with CI-V address of 92”
2025-01-02 10:33:33.914 “Found Rig IC-756 PRO II with CI-V address of 100”
2025-01-02 10:33:33.918 “Found Rig IC-756 PRO III with CI-V address of 110”
2025-01-02 10:33:33.924 “Found Rig IC-7610 with CI-V address of 152”
2025-01-02 10:33:33.931 “Found Rig IC-785x with CI-V address of 142”
2025-01-02 10:33:33.937 “Found Rig IC-905 with CI-V address of 172”
2025-01-02 10:33:33.942 “Found Rig IC-9100 with CI-V address of 124”
2025-01-02 10:33:33.947 “Found Rig IC-9700 with CI-V address of 162”
2025-01-02 10:33:33.949 “Found Rig IC-R7100 with CI-V address of 52”
2025-01-02 10:33:33.950 “Found Rig IC-R8500 with CI-V address of 74”
2025-01-02 10:33:33.954 “Found Rig IC-R8600 with CI-V address of 150”
2025-01-02 10:33:33.956 “Found Rig ID-31A/E with CI-V address of 132”
2025-01-02 10:33:33.957 Loading settings from: “/home/sq9fk/.local/share/wfview/wfserver/.config/wfview/wfserver.conf”
2025-01-02 10:33:33.958 Loading settings from “/home/sq9fk/.local/share/wfview/wfserver/.config/wfview/wfserver.conf”
2025-01-02 10:33:33.993 Serial Port found: “ttyUSB3” Manufacturer: “FTDI” Product ID “FT232R USB UART” S/N “A505RC8D”
2025-01-02 10:33:33.993 Serial Port found: “ttyUSB0” Manufacturer: “Silicon Labs” Product ID “CP2102 USB to UART Bridge Controller” S/N “IC-7100_03004747_A”
2025-01-02 10:33:33.993 Serial Port found: “ttyUSB2” Manufacturer: “Silicon Labs” Product ID “CP2102 USB to UART Bridge Controller” S/N “IC-7100_03004747_B”
2025-01-02 10:33:33.993 Serial Port found: “ttyUSB1” Manufacturer: “Silicon Labs” Product ID “CP2102 USB to UART Bridge Controller” S/N “IC-7300_03001443”
2025-01-02 10:33:33.993 Serial Port found: “ttyS0” Manufacturer: “” Product ID “” S/N “”
2025-01-02 10:33:33.994 Audio device(s) found (*=default)
2025-01-02 10:33:37.303 * ( 0 “alsa” ) Input Device : “default”
2025-01-02 10:33:37.303 ( 1 “alsa” ) Input Device : “sysdefault”
2025-01-02 10:33:37.303 ( 2 “alsa” ) Input Device : “lavrate”
2025-01-02 10:33:37.303 ( 3 “alsa” ) Input Device : “samplerate”
2025-01-02 10:33:37.304 ( 4 “alsa” ) Input Device : “speexrate”
2025-01-02 10:33:37.304 ( 5 “alsa” ) Input Device : “jack”
2025-01-02 10:33:37.304 ( 6 “alsa” ) Input Device : “oss”
2025-01-02 10:33:37.304 ( 7 “alsa” ) Input Device : “pulse”
2025-01-02 10:33:37.304 ( 8 “alsa” ) Input Device : “speex”
2025-01-02 10:33:37.304 ( 9 “alsa” ) Input Device : “upmix”
2025-01-02 10:33:37.304 ( 10 “alsa” ) Input Device : “vdownmix”
2025-01-02 10:33:37.304 ( 11 “alsa” ) Input Device : “usbstream:CARD=vc4hdmi0”
2025-01-02 10:33:37.304 ( 12 “alsa” ) Input Device : “usbstream:CARD=vc4hdmi1”
2025-01-02 10:33:37.305 ( 13 “alsa” ) Input Device : “usbstream:CARD=Headphones”
2025-01-02 10:33:37.305 ( 14 “alsa” ) Input Device : “hw:CARD=CODEC,DEV=0”
2025-01-02 10:33:37.305 ( 15 “alsa” ) Input Device : “plughw:CARD=CODEC,DEV=0”
2025-01-02 10:33:37.305 ( 16 “alsa” ) Input Device : “sysdefault:CARD=CODEC”
2025-01-02 10:33:37.305 ( 17 “alsa” ) Input Device : “front:CARD=CODEC,DEV=0”
2025-01-02 10:33:37.305 ( 18 “alsa” ) Input Device : “dsnoop:CARD=CODEC,DEV=0”
2025-01-02 10:33:37.305 ( 19 “alsa” ) Input Device : “usbstream:CARD=CODEC”
2025-01-02 10:33:37.305 ( 20 “alsa” ) Input Device : “hw:CARD=CODEC_1,DEV=0”
2025-01-02 10:33:37.305 ( 21 “alsa” ) Input Device : “plughw:CARD=CODEC_1,DEV=0”
2025-01-02 10:33:37.306 ( 22 “alsa” ) Input Device : “sysdefault:CARD=CODEC_1”
2025-01-02 10:33:37.306 ( 23 “alsa” ) Input Device : “front:CARD=CODEC_1,DEV=0”
2025-01-02 10:33:37.306 ( 24 “alsa” ) Input Device : “dsnoop:CARD=CODEC_1,DEV=0”
2025-01-02 10:33:37.306 ( 25 “alsa” ) Input Device : “usbstream:CARD=CODEC_1”
2025-01-02 10:33:37.306 ( 26 “alsa” ) Input Device : “hw:CARD=Loopback,DEV=0”
2025-01-02 10:33:37.306 ( 27 “alsa” ) Input Device : “hw:CARD=Loopback,DEV=1”
2025-01-02 10:33:37.306 ( 28 “alsa” ) Input Device : “plughw:CARD=Loopback,DEV=0”
2025-01-02 10:33:37.306 ( 29 “alsa” ) Input Device : “plughw:CARD=Loopback,DEV=1”
2025-01-02 10:33:37.306 ( 30 “alsa” ) Input Device : “sysdefault:CARD=Loopback”
2025-01-02 10:33:37.306 ( 31 “alsa” ) Input Device : “front:CARD=Loopback,DEV=0”
2025-01-02 10:33:37.307 ( 32 “alsa” ) Input Device : “dsnoop:CARD=Loopback,DEV=0”
2025-01-02 10:33:37.307 ( 33 “alsa” ) Input Device : “dsnoop:CARD=Loopback,DEV=1”
2025-01-02 10:33:37.307 ( 34 “alsa” ) Input Device : “usbstream:CARD=Loopback”
2025-01-02 10:33:37.307 ( 35 “alsa” ) Input Device : “hw:CARD=Loopback_1,DEV=0”
2025-01-02 10:33:37.307 ( 36 “alsa” ) Input Device : “hw:CARD=Loopback_1,DEV=1”
2025-01-02 10:33:37.307 ( 37 “alsa” ) Input Device : “plughw:CARD=Loopback_1,DEV=0”
2025-01-02 10:33:37.307 ( 38 “alsa” ) Input Device : “plughw:CARD=Loopback_1,DEV=1”
2025-01-02 10:33:37.307 ( 39 “alsa” ) Input Device : “sysdefault:CARD=Loopback_1”
2025-01-02 10:33:37.307 ( 40 “alsa” ) Input Device : “front:CARD=Loopback_1,DEV=0”
2025-01-02 10:33:37.307 ( 41 “alsa” ) Input Device : “dsnoop:CARD=Loopback_1,DEV=0”
2025-01-02 10:33:37.307 ( 42 “alsa” ) Input Device : “dsnoop:CARD=Loopback_1,DEV=1”
2025-01-02 10:33:37.307 ( 43 “alsa” ) Input Device : “usbstream:CARD=Loopback_1”
2025-01-02 10:33:37.308 ( 44 “default” ) Input Device : “alsa_output.usb-Burr-Brown_from_TI_USB_Audio_CODEC-00.2.analog-stereo.monitor”
2025-01-02 10:33:37.308 ( 45 “default” ) Input Device : “alsa_output.usb-Burr-Brown_from_TI_USB_Audio_CODEC-00.analog-stereo.monitor”
2025-01-02 10:33:37.308 ( 46 “default” ) Input Device : “alsa_input.usb-Burr-Brown_from_TI_USB_Audio_CODEC-00.analog-stereo”
2025-01-02 10:33:37.308 ( 47 “default” ) Input Device : “alsa_input.usb-Burr-Brown_from_TI_USB_Audio_CODEC-00.2.analog-stereo”
2025-01-02 10:33:37.308 ( 48 “default” ) Input Device : “alsa_output.platform-snd_aloop.0.analog-stereo.monitor”
2025-01-02 10:33:37.308 ( 49 “default” ) Input Device : “alsa_input.platform-snd_aloop.0.analog-stereo”
2025-01-02 10:33:37.308 ( 50 “default” ) Input Device : “alsa_output.platform-snd_aloop.1.analog-stereo.monitor”
2025-01-02 10:33:37.308 ( 51 “default” ) Input Device : “alsa_input.platform-snd_aloop.1.analog-stereo”
2025-01-02 10:33:43.579 * ( 0 “alsa” ) Output Device : “default”
2025-01-02 10:33:43.579 ( 1 “alsa” ) Output Device : “sysdefault”
2025-01-02 10:33:43.579 ( 2 “alsa” ) Output Device : “lavrate”
2025-01-02 10:33:43.579 ( 3 “alsa” ) Output Device : “samplerate”
2025-01-02 10:33:43.579 ( 4 “alsa” ) Output Device : “speexrate”
2025-01-02 10:33:43.579 ( 5 “alsa” ) Output Device : “jack”
2025-01-02 10:33:43.580 ( 6 “alsa” ) Output Device : “oss”
2025-01-02 10:33:43.580 ( 7 “alsa” ) Output Device : “pulse”
2025-01-02 10:33:43.580 ( 8 “alsa” ) Output Device : “speex”
2025-01-02 10:33:43.580 ( 9 “alsa” ) Output Device : “upmix”
2025-01-02 10:33:43.580 ( 10 “alsa” ) Output Device : “vdownmix”
2025-01-02 10:33:43.580 ( 11 “alsa” ) Output Device : “hw:CARD=vc4hdmi0,DEV=0”
2025-01-02 10:33:43.580 ( 12 “alsa” ) Output Device : “plughw:CARD=vc4hdmi0,DEV=0”
2025-01-02 10:33:43.580 ( 13 “alsa” ) Output Device : “sysdefault:CARD=vc4hdmi0”
2025-01-02 10:33:43.580 ( 14 “alsa” ) Output Device : “hdmi:CARD=vc4hdmi0,DEV=0”
2025-01-02 10:33:43.580 ( 15 “alsa” ) Output Device : “dmix:CARD=vc4hdmi0,DEV=0”
2025-01-02 10:33:43.580 ( 16 “alsa” ) Output Device : “usbstream:CARD=vc4hdmi0”
2025-01-02 10:33:43.580 ( 17 “alsa” ) Output Device : “hw:CARD=vc4hdmi1,DEV=0”
2025-01-02 10:33:43.580 ( 18 “alsa” ) Output Device : “plughw:CARD=vc4hdmi1,DEV=0”
2025-01-02 10:33:43.581 ( 19 “alsa” ) Output Device : “sysdefault:CARD=vc4hdmi1”
2025-01-02 10:33:43.581 ( 20 “alsa” ) Output Device : “hdmi:CARD=vc4hdmi1,DEV=0”
2025-01-02 10:33:43.581 ( 21 “alsa” ) Output Device : “dmix:CARD=vc4hdmi1,DEV=0”
2025-01-02 10:33:43.581 ( 22 “alsa” ) Output Device : “usbstream:CARD=vc4hdmi1”
2025-01-02 10:33:43.581 ( 23 “alsa” ) Output Device : “hw:CARD=Headphones,DEV=0”
2025-01-02 10:33:43.581 ( 24 “alsa” ) Output Device : “plughw:CARD=Headphones,DEV=0”
2025-01-02 10:33:43.581 ( 25 “alsa” ) Output Device : “sysdefault:CARD=Headphones”
2025-01-02 10:33:43.581 ( 26 “alsa” ) Output Device : “dmix:CARD=Headphones,DEV=0”
2025-01-02 10:33:43.581 ( 27 “alsa” ) Output Device : “usbstream:CARD=Headphones”
2025-01-02 10:33:43.581 ( 28 “alsa” ) Output Device : “hw:CARD=CODEC,DEV=0”
2025-01-02 10:33:43.581 ( 29 “alsa” ) Output Device : “plughw:CARD=CODEC,DEV=0”
2025-01-02 10:33:43.581 ( 30 “alsa” ) Output Device : “sysdefault:CARD=CODEC”
2025-01-02 10:33:43.581 ( 31 “alsa” ) Output Device : “front:CARD=CODEC,DEV=0”
2025-01-02 10:33:43.581 ( 32 “alsa” ) Output Device : “surround21:CARD=CODEC,DEV=0”
2025-01-02 10:33:43.582 ( 33 “alsa” ) Output Device : “surround40:CARD=CODEC,DEV=0”
2025-01-02 10:33:43.582 ( 34 “alsa” ) Output Device : “surround41:CARD=CODEC,DEV=0”
2025-01-02 10:33:43.582 ( 35 “alsa” ) Output Device : “surround50:CARD=CODEC,DEV=0”
2025-01-02 10:33:43.582 ( 36 “alsa” ) Output Device : “surround51:CARD=CODEC,DEV=0”
2025-01-02 10:33:43.582 ( 37 “alsa” ) Output Device : “surround71:CARD=CODEC,DEV=0”
2025-01-02 10:33:43.583 ( 38 “alsa” ) Output Device : “iec958:CARD=CODEC,DEV=0”
2025-01-02 10:33:43.583 ( 39 “alsa” ) Output Device : “dmix:CARD=CODEC,DEV=0”
2025-01-02 10:33:43.583 ( 40 “alsa” ) Output Device : “usbstream:CARD=CODEC”
2025-01-02 10:33:43.583 ( 41 “alsa” ) Output Device : “hw:CARD=CODEC_1,DEV=0”
2025-01-02 10:33:43.583 ( 42 “alsa” ) Output Device : “plughw:CARD=CODEC_1,DEV=0”
2025-01-02 10:33:43.583 ( 43 “alsa” ) Output Device : “sysdefault:CARD=CODEC_1”
2025-01-02 10:33:43.583 ( 44 “alsa” ) Output Device : “front:CARD=CODEC_1,DEV=0”
2025-01-02 10:33:43.583 ( 45 “alsa” ) Output Device : “surround21:CARD=CODEC_1,DEV=0”
2025-01-02 10:33:43.583 ( 46 “alsa” ) Output Device : “surround40:CARD=CODEC_1,DEV=0”
2025-01-02 10:33:43.584 ( 47 “alsa” ) Output Device : “surround41:CARD=CODEC_1,DEV=0”
2025-01-02 10:33:43.584 ( 48 “alsa” ) Output Device : “surround50:CARD=CODEC_1,DEV=0”
2025-01-02 10:33:43.584 ( 49 “alsa” ) Output Device : “surround51:CARD=CODEC_1,DEV=0”
2025-01-02 10:33:43.584 ( 50 “alsa” ) Output Device : “surround71:CARD=CODEC_1,DEV=0”
2025-01-02 10:33:43.584 ( 51 “alsa” ) Output Device : “iec958:CARD=CODEC_1,DEV=0”
2025-01-02 10:33:43.584 ( 52 “alsa” ) Output Device : “dmix:CARD=CODEC_1,DEV=0”
2025-01-02 10:33:43.584 ( 53 “alsa” ) Output Device : “usbstream:CARD=CODEC_1”
2025-01-02 10:33:43.584 ( 54 “alsa” ) Output Device : “hw:CARD=Loopback,DEV=0”
2025-01-02 10:33:43.584 ( 55 “alsa” ) Output Device : “hw:CARD=Loopback,DEV=1”
2025-01-02 10:33:43.584 ( 56 “alsa” ) Output Device : “plughw:CARD=Loopback,DEV=0”
2025-01-02 10:33:43.584 ( 57 “alsa” ) Output Device : “plughw:CARD=Loopback,DEV=1”
2025-01-02 10:33:43.584 ( 58 “alsa” ) Output Device : “sysdefault:CARD=Loopback”
2025-01-02 10:33:43.584 ( 59 “alsa” ) Output Device : “front:CARD=Loopback,DEV=0”
2025-01-02 10:33:43.584 ( 60 “alsa” ) Output Device : “surround21:CARD=Loopback,DEV=0”
2025-01-02 10:33:43.585 ( 61 “alsa” ) Output Device : “surround40:CARD=Loopback,DEV=0”
2025-01-02 10:33:43.585 ( 62 “alsa” ) Output Device : “surround41:CARD=Loopback,DEV=0”
2025-01-02 10:33:43.585 ( 63 “alsa” ) Output Device : “surround50:CARD=Loopback,DEV=0”
2025-01-02 10:33:43.586 ( 64 “alsa” ) Output Device : “surround51:CARD=Loopback,DEV=0”
2025-01-02 10:33:43.586 ( 65 “alsa” ) Output Device : “surround71:CARD=Loopback,DEV=0”
2025-01-02 10:33:43.586 ( 66 “alsa” ) Output Device : “dmix:CARD=Loopback,DEV=0”
2025-01-02 10:33:43.586 ( 67 “alsa” ) Output Device : “dmix:CARD=Loopback,DEV=1”
2025-01-02 10:33:43.586 ( 68 “alsa” ) Output Device : “usbstream:CARD=Loopback”
2025-01-02 10:33:43.586 ( 69 “alsa” ) Output Device : “hw:CARD=Loopback_1,DEV=0”
2025-01-02 10:33:43.586 ( 70 “alsa” ) Output Device : “hw:CARD=Loopback_1,DEV=1”
2025-01-02 10:33:43.586 ( 71 “alsa” ) Output Device : “plughw:CARD=Loopback_1,DEV=0”
2025-01-02 10:33:43.586 ( 72 “alsa” ) Output Device : “plughw:CARD=Loopback_1,DEV=1”
2025-01-02 10:33:43.586 ( 73 “alsa” ) Output Device : “sysdefault:CARD=Loopback_1”
2025-01-02 10:33:43.586 ( 74 “alsa” ) Output Device : “front:CARD=Loopback_1,DEV=0”
2025-01-02 10:33:43.587 ( 75 “alsa” ) Output Device : “surround21:CARD=Loopback_1,DEV=0”
2025-01-02 10:33:43.587 ( 76 “alsa” ) Output Device : “surround40:CARD=Loopback_1,DEV=0”
2025-01-02 10:33:43.587 ( 77 “alsa” ) Output Device : “surround41:CARD=Loopback_1,DEV=0”
2025-01-02 10:33:43.587 ( 78 “alsa” ) Output Device : “surround50:CARD=Loopback_1,DEV=0”
2025-01-02 10:33:43.587 ( 79 “alsa” ) Output Device : “surround51:CARD=Loopback_1,DEV=0”
2025-01-02 10:33:43.587 ( 80 “alsa” ) Output Device : “surround71:CARD=Loopback_1,DEV=0”
2025-01-02 10:33:43.587 ( 81 “alsa” ) Output Device : “dmix:CARD=Loopback_1,DEV=0”
2025-01-02 10:33:43.587 ( 82 “alsa” ) Output Device : “dmix:CARD=Loopback_1,DEV=1”
2025-01-02 10:33:43.587 ( 83 “alsa” ) Output Device : “usbstream:CARD=Loopback_1”
2025-01-02 10:33:43.587 ( 84 “default” ) Output Device : “alsa_output.usb-Burr-Brown_from_TI_USB_Audio_CODEC-00.2.analog-stereo”
2025-01-02 10:33:43.587 ( 85 “default” ) Output Device : “alsa_output.usb-Burr-Brown_from_TI_USB_Audio_CODEC-00.analog-stereo”
2025-01-02 10:33:43.587 ( 86 “default” ) Output Device : “alsa_output.platform-snd_aloop.0.analog-stereo”
2025-01-02 10:33:43.587 ( 87 “default” ) Output Device : “alsa_output.platform-snd_aloop.1.analog-stereo”
2025-01-02 10:33:43.588 Rig “IC-7100_03004747_A” configured rxAudio device: “default”
2025-01-02 10:33:43.588 Rig “IC-7100_03004747_A” configured txAudio device: “default”
2025-01-02 10:33:43.588 "IC-7100_03004747_A Audio input device default found! "
2025-01-02 10:33:43.588 "IC-7100_03004747_A Audio output device default found! "
2025-01-02 10:33:43.588 Creating new rigThread()
2025-01-02 10:33:43.588 creating instance of rigCommander()
2025-01-02 10:33:43.588 Returning instance of cachingQueue() to calling process: “”
2025-01-02 10:33:43.588 creating instance of icomCommander() with GUID
2025-01-02 10:33:43.589 Rig thread is running
2025-01-02 10:33:43.589 Starting udp server
2025-01-02 10:33:43.589 Returning instance of cachingQueue() to calling process: “”
2025-01-02 10:33:43.589 CIV: 0
2025-01-02 10:33:43.590 Model: “”
2025-01-02 10:33:43.590 Name: “IC-7100_03004747_A”
2025-01-02 10:33:43.590 CIV: 0
2025-01-02 10:33:43.590 GUID: {2f7cbbe6-5da6-4b0c-811f-3afeb674dda8}
2025-01-02 10:33:43.593 My IP Address: “0.0.0.0”
2025-01-02 10:33:43.594 Server Bound Control to: 50001
2025-01-02 10:33:43.594 Server Bound CI-V to: 50002
2025-01-02 10:33:43.594 Server Bound Audio to: 50003
2025-01-02 10:33:43.600 Opened port: “ttyUSB0”
2025-01-02 10:33:43.601 Returning instance of cachingQueue() to calling process: “”
2025-01-02 10:33:43.601 Received CommReady!!
Server connections: Control:0 CI-V:0 Audio:0
2025-01-02 10:33:44.076 Searching for rig on “ttyUSB0”
As You see conf file is not used.
Piotr SQ9FK
Why do you think that config file isn’t being used?
As we have stated multiple times in the documentation, you should NEVER specify the CI-V address of the radio unless your radio doesn’t support CI-V transceive mode. Your radio definitely does support it, so CI-V transceive mode must be enabled for wfserver to work properly. It isn’t currently detecting your radio because of this.
Please can you try the password:
 (+\Dz"6w
This is the word password and will confirm proper operation.
Phil:
I’ve defined CI-V to try if something will change. And no nothing change :slight_smile: That’s why it was defined.
Why it’s not used ? Because audio card is not correct and tty port also. I have working symlink to ttyIC7300 which works on wfview and it’s not ttyUSB0 (ttyUSB0 i different radio).
Incorrect login… mainly because config file is not in action as I said.
I have just seen how you are specifying the config file, it MUST be just the filename, not a path
wfserver -d -s wfserver.conf
Although that is unnecessary as its the default config filename anyway.
What you are specifiing is trying to load:
"/home/sq9fk/.local/share/wfview/wfserver/.config/wfview/wfserver.conf”
As you can clearly see from the log.
Please edit the correct config file which is /home/sq9fk/.local/share/wfview/wfserver/wfserver.conf (it might be .config by default, I am not sure.)
Now works! Great.
Thank You very much.
But as feature tyere should be possibility to define own paths for configs
Piotr SQ9FK
There is. If you specify an absolute path (starting with a /) this is detected and properly handled, but you specified a relative path (without a leading /) so wfview has no idea what directory it is supposed to start in.
It’s should be ~/ like normal linux.
SQ9FK
That is not the case, the default directory is wherever you run it from.
