WFVIEW 2.0.3 not working with wsjt-x
I installed wfview 2.03 with my icom 705.
Will not work with wsjt-x v2.61.
When I turn the dial, it takes 5 seconds to refresh.
Test CAT is green.
Downgraded to wfview 2.01 and everything works. js8callm fldifi and wsjt-x.
U[graded to 2.03 - does not work.
Config settings were checked\ and matched.
Any reason?
I am also experiencing a similar problem between wfview 2.03, wsjt-x 2.61, and my ICOM 705. I am running wfview on my Windows 11 laptop connected to the 705 via WLAN. All was well with wfview 2.01. I did updated the rig files for 2.03 as well. Any insight would be helpful. Thanks very much for the development and support!
Here’s a wfview log from connecting to the radio, starting wsjt-x, and then trying to switch from 40 m to 17 m via wsjt-x. https://termbin.com/mtaf
The following text is from the wsjt-x error window when trying to switch to 17 m:
Hamlib error: read_string_generic(): RX 8 characters, direct=1
*0000 52 50 52 54 20 2d 31 0a RPRT -1. *
netrigctl_set_vfo called
netrigctl_set_vfo: cmd='V None
netrigctl_transaction: called len=7
rig_flush: called for network device
network_flush called
write_block(): TX 7 bytes, method=2
*0000 56 20 4e 6f 6e 65 0a V None. *
read_string_generic called, rxmax=1024 direct=1, expected_len=1
read_string_generic(): RX 7 characters, direct=1
*0000 52 50 52 54 20 30 0a RPRT 0. *
Invalid parameter
0:rig_set_mode: elapsed=1ms
0:rig.c(2369):rig_set_mode returning(-1) Invalid parameter
Invalid parameter
Invalid parameter
  • while setting current VFO mode*
Timestamp: 2025-01-12T16:34:20.158Z
