I have an IC-9700 connected via ethernet which now works well under v2.03 (initial hiccup with Windows 23H2 update). I’m using the two shortcut method to access my IC-7300 via USB. However the IC-7300 only displays the waterfall, there is no Audio on my PC. The IC-7300 is setup according to Elliott’s Power-point presentation (7300 setup - Google Slides)
I have since installed the Windows 24H2 update but still no Audio.
Attached is the link to my Log file: https://termbin.com/ouzk
What am I doing wrong?
Nothing… Unless you are using wfview as a server, it doesn’t do anything with the audio from USB connected radios.
