I took my Chromebook to the pub for dinner tonight hoping to work digital modes remotely using only remote desktop (NoMachine). Unfortunately, I forgot to enable CI-V Tranceive on my Icom 7610 so here I sit crying in my beer…
Note that I have proven that I can access and use WFView this way.. but only if I remember to turn on CI-V Transceive before I leave!
WFView is installed and working on my home QTH PC. I use NoMachine to connect to my desktop. I do not run WFView on my remote computer. The reason for this is that I want to remotely access other programs in addition to WFView, especially digital mode utilities. For example, I use WSJT-x and VarAC utilities, and my general logger, Log4OM. By using NoMachine to access my desktop rather than installing all that software on my remote machine, I simplify my remote device considerably. And in this case, I can use a Chromebook! The only program to install is NoMachine. NoMachine is a great solution/
There are other desktop sharing applications, but NoMachine also includes the audio stream which is critical.
OK, all that is working. But here is my problem (in addition to being locked out since I did not enable CI-Vs Tranceive) ….WFView requires CI-V to be enabled, and many of my accessory programs use Omnirig for CAT control (including WSJT-x, VarAC, and my generally logger, Log4OM). But OmniRig does not like having CI-V Tranceive enabled! Thus the conundrum. I cannot use remote desktop to run WFView (connected locally) AND also run Omnirig at the same time. This prevents me from from using remote desktop as a full remote solution.
So, pending any suggestions from members or developers, I have an idea. Would it be possible to configure WFView to optionally use BOTH the TCP protocol AND OmniRig (or a USB direct protocol) for all CAT control functions?
Hmm… I just realized that CI-V Tranceive will still be turned on and could confuse OmniRig. Hmm… does anyone know if that will be an issue?
WFView is a great program, but at least in my case is seriously cobbled by problems integrating with one of the most popular CAT control tools in the Amateur community. Note that I’m not blaming WFView, its more of a problem with OmniRig, but I have no idea how to ping the developers of Omnirig.
Getting back to my actual issue tonight… is there any way to enable CI-V Tranceive remotely when it is not already enabled? (related…I have not seen any 3rd party software that can access the ICOM menu settings….).
