somtime the client will connect wright away but most times it can take 10 mins or so
More information please.
when trying to connect to my server sometime it connect fast but most of the time it takes 5 or more minutes
Simply re-wording the statement is not providing more information. You haven’t given even the most basic details about your setup. How can you possibly expect anybody to be able to provide assistance?
I have server on main pc win 11 and client on my laptop i also use rcforb with no problems
not a firewall issue just very slow to connect if i use the next door wifi it connects fine thanks
also i have very fast wifi
again, without any details, logs etc it is impossible to say anything, except for what we wrote already.
update first to the latest client version.
ok UPDATED BUT NO CHANGE I run an Icom 7300 with wfview The problem is with my router (i think) the router is an at&t BGW 320-500 ports are forwared and it does connect and work fine on the first try But if i disconnect and try again it will NOT connect anyone usging thw BGW320-500?
Log file from first successful connection and second failed connection please.
Follow these directions carefully to send both:
Please do not send us a screenshot or photo of the log.
Thank you for sending these.
Everything looks pretty nominal.
Can you do the same for the server side?
