WFView has error as follows:
program was working correctly in past, can you asists
Don Westacott VE6HQ
| 2026-06-08 08:20:35.557 WRN default: Cannot draw meter without scale data! |
2026-06-08 08:20:35.568 WRN default: Cannot draw meter without scale data!
2026-06-08 08:20:35.674 INF udp: Closing UDP stream : “10.0.0.30” : 50001
2026-06-08 08:20:35.675 INF rig: [SHUTDOWN] ~icomCommander enter
2026-06-08 08:20:35.675 INF rig: closing instance of rigCommander()
2026-06-08 08:20:45.278 INF rig: creating instance of rigCommander()
2026-06-08 08:20:45.278 INF rig: creating instance of icomCommander()
2026-06-08 08:20:45.279 INF udp: Starting icomUdpHandler user: “VE6HQ” rx latency: 100 tx latency: 100 rx sample rate: 16000 rx codec: 4 tx sample rate: 16000 tx codec: 4
2026-06-08 08:20:45.282 INF udp: UDP Stream bound to local port: 61299 remote port: 50001
2026-06-08 08:21:03.977 WRN default: Cannot draw meter without scale data!
2026-06-08 08:21:03.987 WRN default: Cannot draw meter without scale data!
2026-06-08 08:21:20.010 WRN default: Cannot draw meter without scale data!
2026-06-08 08:21:20.024 WRN default: Cannot draw meter without scale data!
2026-06-08 08:21:20.161 WRN default: Cannot draw meter without scale data!
2026-06-08 08:21:20.172 WRN default: Cannot draw meter without scale data!
2026-06-08 08:21:45.277 WRN system: No response received to connection request
2026-06-08 08:21:45.277 INF udp: Closing UDP stream : “10.0.0.30” : 50001
2026-06-08 08:21:45.278 INF rig: [SHUTDOWN] ~icomCommander enter
2026-06-08 08:21:45.278 INF rig: closing instance of rigCommander()
2026-06-08 08:21:45.278 INF rig: creating instance of rigCommander()
2026-06-08 08:21:45.278 INF rig: creating instance of icomCommander()
2026-06-08 08:21:45.279 INF udp: Starting icomUdpHandler user: “VE6HQ” rx latency: 100 tx latency: 100 rx sample rate: 16000 rx codec: 4 tx sample rate: 16000 tx codec: 4
2026-06-08 08:21:45.283 INF udp: UDP Stream bound to local port: 57350 remote port: 50001
2026-06-08 08:22:45.301 WRN system: No response received to connection request
2026-06-08 08:22:45.301 INF rig: [SHUTDOWN] ~icomCommander enter
2026-06-08 08:22:45.302 INF udp: Closing UDP stream : “10.0.0.30” : 50001
2026-06-08 08:22:45.302 INF rig: closing instance of rigCommander()
2026-06-08 08:22:45.303 INF rig: creating instance of rigCommander()
2026-06-08 08:22:45.303 INF rig: creating instance of icomCommander()
2026-06-08 08:22:45.304 INF udp: Starting icomUdpHandler user: “VE6HQ” rx latency: 100 tx latency: 100 rx sample rate: 16000 rx codec: 4 tx sample rate: 16000 tx codec: 4
2026-06-08 08:22:45.308 INF udp: UDP Stream bound to local port: 58099 remote port: 50001
2026-06-08 08:23:45.304 WRN system: No response received to connection request
2026-06-08 08:23:45.304 INF udp: Closing UDP stream : “10.0.0.30” : 50001
2026-06-08 08:23:45.305 INF rig: [SHUTDOWN] ~icomCommander enter
2026-06-08 08:23:45.305 INF rig: closing instance of rigCommander()
2026-06-08 08:23:45.306 INF rig: creating instance of rigCommander()
2026-06-08 08:23:45.306 INF rig: creating instance of icomCommander()
2026-06-08 08:23:45.307 INF udp: Starting icomUdpHandler user: “VE6HQ” rx latency: 100 tx latency: 100 rx sample rate: 16000 rx codec: 4 tx sample rate: 16000 tx codec: 4
2026-06-08 08:23:45.310 INF udp: UDP Stream bound to local port: 59176 remote port: 50001
