WFView, Icom 7700 and disappearing waterfall
Greetings all! First off, I am very excited to have found this project. I was somewhat resigned to thinking that I would be limited to using the RS-BA1 software (ie, stuck on windows). Looking things over, I have wfview up and running, except that when I connect to the set, my waterfall disappears. As in, completely!
Looking at log output, I don’t see anything that really stands out to me except this bit for the audioconverter (see below). What am I missing here?
2024-01-08 16:06:23.816 INF udp: Starting udpHandler user: "RPOPP" rx latency: 150 tx latency: 150 rx sample rate: 48000 rx codec: 4 tx sample rate: 48000 tx codec: 4
2024-01-08 16:06:26.945 INF system: Received CommReady!!
2024-01-08 16:06:26.945 INF udp: UDP Stream bound to local port: 40419 remote port: 50001
2024-01-08 16:06:26.945 INF default: Setting rig state for wfmain
2024-01-08 16:06:27.470 INF udp: udpHandler : Received I am here from: QHostAddress("::ffff:192.168.2.32")
2024-01-08 16:06:27.471 INF udp: udpHandler : Received I am ready
2024-01-08 16:06:27.471 INF udp: udpHandler : Sending login packet
2024-01-08 16:06:27.475 INF udp: Got connection type: "FTTH"
2024-01-08 16:06:27.475 INF udp: udpHandler : Received matching token response to our request
2024-01-08 16:06:27.475 INF udp: udpHandler : Detected connection speed FTTH
2024-01-08 16:06:27.477 INF udp: udpHandler "Received radio capabilities, Name: IC-7700, Audio: ICOM_VAUDIO, CIV: 77, MAC: 00:90:c7:03:75:e1 CAPF: 5001"
2024-01-08 16:06:27.477 INF udp: Got Connection status for: IC-7700 Busy: 0 Computer IP "0.0.0.0"
2024-01-08 16:06:27.477 INF udp: Got Radio 0
2024-01-08 16:06:27.477 INF udp: Find available local ports
2024-01-08 16:06:27.477 INF default: Received serial port baud rate from remote server: 19200
2024-01-08 16:06:27.477 INF system: Delay command interval timing: 75 ms
2024-01-08 16:06:27.479 INF udp: Starting udpCivData
2024-01-08 16:06:27.479 INF udp: UDP Stream bound to local port: 54067 remote port: 50002
2024-01-08 16:06:27.480 INF udp: Starting udpAudio
2024-01-08 16:06:27.480 INF udp: UDP Stream bound to local port: 52990 remote port: 50003
2024-01-08 16:06:27.480 INF audio: Input audio handler starting: "lavrate"
2024-01-08 16:06:27.480 INF audio: Output audio handler starting: "alsa_output.usb-ACTIONS_Pebble_V3-00.analog-stereo"
2024-01-08 16:06:27.480 INF udp: udpHandler Got serial and audio request success, device name: "IC-7700"
2024-01-08 16:06:27.480 INF udp: Got Connection status for: IC-7700 Busy: 1 Computer darkstar-wfview IP "192.168.2.3"
2024-01-08 16:06:27.480 INF audio: Output thread id 0x7f6d1e34f6c0
2024-01-08 16:06:27.480 INF audio: Output start() running
2024-01-08 16:06:27.480 INF udp: udpCivData : Received I am here
2024-01-08 16:06:27.480 INF audioconverter: Starting audioConverter() Input: 1 Channels of 0 48000 SignedInt 16 Output: 2 Channels of 0 48000 SignedInt 16
2024-01-08 16:06:27.480 INF udp: udpAudio : Received I am here
2024-01-08 16:06:27.480 CRT audio: Input Cannot request 48K, reverting to 8000
2024-01-08 16:06:27.480 INF audio: Input thread id 0x7f6d1eb506c0
2024-01-08 16:06:27.480 INF audio: Input start() running
2024-01-08 16:06:27.480 INF audioconverter: Starting audioConverter() Input: 2 Channels of 0 8000 SignedInt 16 Output: 1 Channels of 0 48000 SignedInt 16
2024-01-08 16:06:27.481 INF audioconverter: wf_resampler_init() returned: 0 resampleRatio: 6
2024-01-08 16:06:27.496 WRN default: QObject::connect: Cannot connect QAudioInput::destroyed() to (nullptr)::deleteLater()
2024-01-08 16:06:27.496 WRN default: QObject::connect: Cannot connect (nullptr)::readyRead() to audioHandler::getNextAudioChunk()
2024-01-08 16:06:27.496 INF audio: Input Audio device failed to start()
2024-01-08 16:06:27.557 INF rig: Using incomingCIVAddr: (int): 119 hex: "0x77"
2024-01-08 16:06:27.557 INF serial: Received rigCapabilities for "IC-7700"
2024-01-08 16:06:27.557 INF rig: Have rig ID: decimal: 116
2024-01-08 16:06:27.557 INF system: Delay command interval timing: 25 ms
Hello,
Unfortunately, the IC-7700 does not provide waterfall data. That is why it is not displayed. The best you can do is to run something like fldigi on the audio stream. You could also investigate installing an RTL-SDR “tap” into the radio and using that, which can be streamed out using a raspberry pi.
Please keep us posted on your adventures with the 7700, we have few user reports and would like more!
