Doug,
it’s simple.
wfview/RSBA1 support NAT
They don’t support PAT
Last time I asked you to answer the questions, you were telling met tI was sarcastic, fine by me. Because I am, when triggered.
Now, Elliott asked the following question:
“I asked if the port numbers are the same on both sides. I did not ask if you think they are correct,”
So we are talking about portforwarding.
“The router has been setup for port forwarding so that 50001-50003 go to the Widows computer at 192.168.1.125 running as the wfview server for the IC-7300 and 50004-50006 are forwarded to the IC-7610 at 192.168.128. (Locally the port definitions in the router don’t matter).”
trying to understand the incomplete information you send…:
Tell me what ports and protocol is used from outside to inside for the 7300
Tell me what ports and protocol is used from outside to inside for the 7610
don’t come up with “it’s correct”, no come up with all these details. If you like, you
can leave out your public ip address for now.
And again, if you don’t answer the questions asked, we cannot help you.
so:
ext.ip.address port aaaaa,bbbbb,ccccc, protocol → internal ip address, port xxxxx,yyyyy,xxxxx, protocol, internal address
and that for both the 7300’s server system as well as for the 7610’s address.
and again: wfview/rsba1 works with NAT, not with PAT; that’s how the protocol works.
