Actually trying JS8Call with my IC705. (wirelessly with WFview of course)
Receive works ok, but I keep getting Hamlib I/O connection errors using exactly the same set up as I am using with FreeDV
(which actually works flawlessly of course!)
Rig: Hamlib NET rigctl
Cat Control Network Server: localhost:4533
So I must be missing something obvious
Has anyone else gotten this to work with JS8Call?
73/Rick
W4XA (formerly WA6III)
More…
I set up FLDIGI with little or no problem. Only thing not working there is the ability to monitor audio through the MAC Book speaker. Using the above settings FLDIGI works (I did not use FLRIG to do rig control. Evidently it isn’t needed nor should it be used when using Hamlib NET rigctl)
If there is a malfunction during high-power transmission, it should be caused by the interference of the unbalanced antenna feedback system. It is recommended to use a choke to eliminate it. The production of choke coils uses magnetic rings with a permeability of 850, with a diameter of 5cm or more as much as possible
I am thinking the problem is not RF related since it happens while not transmitting. And when I transmit using FreeDV at up to 500W or so, I have no RF related problems.
Rick did you ever get this resolved? I’m having the same issue with the same setup IC705 ↔ Wi-fi ↔ MacOS ↔ WFview ↔ JS8call with Hamlib NET rigctl and no tx
No I didn’t. And quite frankly, I simply gave up trying to get JS8call to work. It’s only marginally better than FT8 which I find completely useless for any sort of “QSO” mode.
My digital focus has been more aimed at FreeDV since there are a bunch of “keyboard” digital modes out there (including RTTY that the 705 will do internally!) that are much more “conversational”
