Hi. Now on wfview 2.03 using wsjtx 2.7.0
If I leave the rigctld blank in wsjtx and have external control enable rigctld enabled and port set to 4532 in wfview then I can connect .
As I have 2x 7300 I wanted to set a custom port in wfview but that just does not work in wsjtx - no port available errors.
I thought I would set a virtual port in wfview but all I have in the list are ports already in use and I can not manually select them… What am I missing?
73
Dave
