Hello:
Trying a brand new install of 1.0 and when I run wfview-1.0-windows.exe I get…
VCRUNTIME140.DLL not found, followed by…
MSVCP140.DLL not found.
Are there dependencies?
Tom
Hello:
Tom
Hi Thomas,
You might need to download the latest Microsoft Visual C++ Runtime from here.
Let us know if it works,
–Elliott
Note that you need to install both the x86 and x64 versions of the DLL.
Have installed both 86/64 and now the install finished without error.
However, when I run wfview I get…
“The code execution cannot proceed because MSVCP140_1.dll was not found.”
…clicking on OK repeats the error and then OK again exits.
I do see MSVCP140_1.dll in c:\Windwos\System32
(A reinstall did not help.)
Tom
That sounds like you maybe installed the wrong Visual C++ redistributable?
The correct one is also copied into the wfview installation directory (c:\program files\wfview or c:\program files (x86)\wfview) try running that.
That did it!
Thanks!
Tom
Hi Elliott,
I was having the same issue and I did as you suggested. And it fixed the install issue. Thanks. Great program! Thanks for doing this.
jack
Thanks, Jack, glad it’s working.
