I’d like to say thank you for a great program. I’ve been evaluating several options, remote hams, win4icom and wfview. I can tell you that so far wfview comes out on top. The audio quality of CW and SSB far surpasses win4icom. The only advantage I’ve seen from win4icom is the multiple virtual com ports and the ability to use the IQ scope. But for true remoting with the server/client, wfview has the other beat by a mile. I come from an open source background working for Canonical/Ubuntu for 8 years so I tend to gravitate towards open source.
@watchdoctor If you like to play with audio processing (for SSB mode ) try PulseEffect or Easy Effects on FlatHub. I run PulseEffect which pre-processes my TX Audio stream just before getting to the WF-View client. In my case, I’m removing some of the bassy sound from my audio and adding a little mid to the overall tone.
Once you get it set up on client, it always runs as service in the background. the app is merely a control interface to the underlying audio chains set up by the app.
There are other effects to try such as : Gate – which removes any background sounds while you transmit.
(PulseEffect is for PulseAudio enviroment, whereas Easy Effects is for Pipe Wire )
