I have connect to my x6100 with wfview on ras pi 5
Cat works ok but i have no waterfall
How do i identify the audio ports created by x6100 on my pi
Hi Richard.
We have limited knowledge of the x6100 but how are you connecting to it? If via USB then I assume it will create a pair of USB audio interfaces like Icom radios do? If over LAN/WiFi (using the wfserver built into the radio) then it doesn’t create any ports, but if you want to connect to digital mode software like wsjt-x or fldigi, then you will need to create loopback audio ports.
The process for doing this is explained in Audio Configuration | wfview but you may need to do a web search for the specific commands for your Linux distribution.
Phil M0VSE
Im using the precompiled executable on Debian on a pi5. When i connect via usb the rig is identified ok and i have cat control for the x6100. But i do not have spectrum or waterfall i have the same result if i have the wfserver off or on on the x6100
R
Just tested in win 10 Connected via usb
Cat control ok but no spectrum or waterfall
R
What does the lower right corner of wfview say?
