Hello,
first of all thanks for the great software.
I’m now trying a client server installation. I believe that Rig is configured correctly as I’m using Icom RS-BA1 and Win4Icom remotely without any problem.
Right now server is an Ubuntu VM, client is Windows machine.
Code has been compiled from source from latest git.
Server:
- Can connect to the rig. I can see the waterfall, I can operate the radio. I don’t know if audio is present as VM is headless.
Client:
- You can see from the debug messages. I can authenticate with the server but apparently no radio control and no audio.
Server Log:
2022-04-27 09:43:24.747 INF udp: Starting udpHandler user: “sf” rx latency: 150 tx latency: 150 rx sample rate: 48000 rx codec: 64 tx sample rate: 48000 tx codec: 64
2022-04-27 09:43:24.760 INF system: Received CommReady!!
2022-04-27 09:43:24.760 INF default: Setting rig state for wfmain
2022-04-27 09:43:24.760 INF udp: UDP Stream bound to local port: 58008 remote port: 50001
2022-04-27 09:43:25.264 INF udp: udpHandler : Received I am here from: QHostAddress("::ffff:192.168.1.107")
2022-04-27 09:43:25.280 INF udp: udpHandler : Received I am ready
2022-04-27 09:43:25.280 INF udp: udpHandler : Sending login packet
2022-04-27 09:43:25.295 INF udp: Got connection type: “WFVIEW”
2022-04-27 09:43:25.295 INF udp: udpHandler : Received matching token response to our request
2022-04-27 09:43:25.295 DBG udp: udpHandler Sending Token request: 2
2022-04-27 09:43:25.295 INF udp: udpHandler : Detected connection speed WFVIEW
2022-04-27 09:43:25.311 INF udp: udpHandler Received radio capabilities, Name: Audio: ICOM_VAUDIO CIV: 0 CAPF 5001
2022-04-27 09:43:25.369 INF udp: Got Connection status for: Busy: 2 Computer IP “0.0.0.0”
2022-04-27 09:44:25.289 DBG udp: udpHandler Sending Token request: 5
2022-04-27 09:44:25.312 DBG udp: udpHandler : Token renewal successful
2022-04-27 09:44:25.328 INF udp: Starting udpCivData
2022-04-27 09:44:25.328 INF udp: UDP Stream bound to local port: 52749 remote port: 50002
2022-04-27 09:44:25.328 INF udp: Starting udpAudio
2022-04-27 09:44:25.343 INF udp: UDP Stream bound to local port: 52750 remote port: 50003
2022-04-27 09:44:25.345 INF audio: Output audio handler starting: “”
2022-04-27 09:44:25.345 INF udp: udpHandler Got serial and audio request success, device name: “”
2022-04-27 09:44:25.346 DBG audio: Creating Output audio device: “” , bits 8 , codec 64 , latency 150 , localAFGain 255 , radioChan 1 , resampleQuality 4 , samplerate 48000 , uLaw false
2022-04-27 09:44:25.347 DBG audio: Output setVolume: 255 ( 1 )
2022-04-27 09:44:25.347 DBG audio: Output Preferred Format: SampleSize 16 Channel Count 2 Sample Rate 44100 Codec “audio/pcm” Sample Type SignedInt
2022-04-27 09:44:25.347 INF audio: Output Internal: sample rate 44100 channel count 2
2022-04-27 09:44:25.347 INF audio: Creating opus decoder: success
2022-04-27 09:44:25.347 INF audio: Output wf_resampler_init() returned: 0 resampleRatio: 0.91875
2022-04-27 09:44:25.347 INF audio: Output thread id 0x5020
2022-04-27 09:44:25.347 INF audio: Output start() running
2022-04-27 09:44:25.358 INF udp: udpCivData : Received I am here
2022-04-27 09:44:25.384 INF udp: udpAudio : Received I am here
2022-04-27 09:44:27.329 INF udp: CIV Watchdog: no CIV data received for 2s, requesting data start.
2022-04-27 09:44:27.376 INF udp: Audio Watchdog: no audio data received for 2s, restart required?
2022-04-27 09:45:25.317 DBG udp: udpHandler Sending Token request: 5
2022-04-27 09:45:25.321 DBG udp: udpHandler : Token renewal successful
2
Client Log:
2022-04-27 10:32:19.952 INF system: “wfview version: 1.2e (Git:4ba4358 on Apr 27 2022 at 08:56:14 by build@wfview.org)\nOperating System: Windows 10 Version 2009 (i386)\nBuild Qt Version 5.15.2. Current Qt Version: 5.15.2\n”
2022-04-27 10:32:19.952 DBG system: "SerialPortCL as set by parser: "
2022-04-27 10:32:19.952 DBG system: “remote host as set by parser: "
2022-04-27 10:32:19.952 DBG system: “CIV as set by parser: "
2022-04-27 10:32:20.533 DBG system: Running with debugging options enabled.
2022-04-27 10:32:20.533 INF default: setState 1
2022-04-27 10:32:20.533 INF default: setState 0
2022-04-27 10:32:20.543 DBG system: Finding audio input devices
2022-04-27 10:32:21.360 DBG gui: Changed default audio output to: “Speakers (Realtek(R) Audio)”
2022-04-27 10:32:21.360 DBG gui: Changed default server audio output to: “Speakers (Realtek(R) Audio)”
2022-04-27 10:32:21.360 DBG system: Finding audio output devices
2022-04-27 10:32:21.458 DBG gui: Changed default audio input to: “Microphone (Realtek(R) Audio)”
2022-04-27 10:32:21.458 DBG gui: Changed default server audio input to: “Microphone (Realtek(R) Audio)”
2022-04-27 10:32:21.458 DBG system: Audio devices done.
2022-04-27 10:32:21.601 DBG system: Audio set to default device initially
2022-04-27 10:32:21.618 INF system: Loading settings from “\HKEY_CURRENT_USER\Software\wfview\wfview”
2022-04-27 10:32:21.654 INF gui: Got Audio Output: “”
2022-04-27 10:32:21.654 INF gui: Got Audio Input: “”
2022-04-27 10:32:21.654 INF gui: Got Server Audio Input: “Microphone (Realtek(R) Audio)”
2022-04-27 10:32:21.654 INF gui: Got Server Audio Output: “Speakers (Realtek(R) Audio)”
2022-04-27 10:32:21.671 DBG system: Running setUIToPrefs()
2022-04-27 10:32:21.974 INF system: Cannot prepare WF view without rigCaps. Waiting on this.
2022-04-27 10:32:21.974 DBG system: Running setInititalTiming()
2022-04-27 10:32:21.974 DBG system: Running openRig()
2022-04-27 10:32:21.974 DBG system: Serial port not specified.
2022-04-27 10:32:21.974 INF rig: creating instance of rigCommander()
2022-04-27 10:32:21.974 DBG system: Running rigConnections()
2022-04-27 10:32:21.974 INF udp: Starting udpHandler user: “sf” rx latency: 150 tx latency: 150 rx sample rate: 48000 rx codec: 64 tx sample rate: 48000 tx codec: 64
2022-04-27 10:32:21.992 INF udp: UDP Stream bound to local port: 56377 remote port: 50001
2022-04-27 10:32:22.097 INF system: Received CommReady!!
2022-04-27 10:32:22.097 INF default: Setting rig state for wfmain
2022-04-27 10:32:22.516 INF udp: udpHandler : Received I am here from: QHostAddress(”::ffff:192.168.1.107”)
2022-04-27 10:32:22.597 INF udp: udpHandler : Received I am ready
2022-04-27 10:32:22.597 INF udp: udpHandler : Sending login packet
2022-04-27 10:32:22.612 INF udp: Got connection type: “WFVIEW”
2022-04-27 10:32:22.612 INF udp: udpHandler : Received matching token response to our request
2022-04-27 10:32:22.612 DBG udp: udpHandler Sending Token request: 2
2022-04-27 10:32:22.612 INF udp: udpHandler : Detected connection speed WFVIEW
2022-04-27 10:32:22.628 INF udp: udpHandler Received radio capabilities, Name: Audio: ICOM_VAUDIO CIV: 0 CAPF 5001
2022-04-27 10:32:22.628 INF udp: Got Connection status for: Busy: 2 Computer IP “0.0.0.0”
2022-04-27 10:33:22.608 DBG udp: udpHandler Sending Token request: 5
2022-04-27 10:33:22.608 DBG udp: udpHandler : Token renewal successful
2022-04-27 10:33:22.623 INF udp: Starting udpCivData
2022-04-27 10:33:22.623 INF udp: UDP Stream bound to local port: 52441 remote port: 50002
2022-04-27 10:33:22.623 INF udp: Starting udpAudio
2022-04-27 10:33:22.623 INF udp: UDP Stream bound to local port: 52442 remote port: 50003
2022-04-27 10:33:22.639 INF udp: udpHandler Got serial and audio request success, device name: “”
2022-04-27 10:33:22.639 INF audio: Output audio handler starting: “”
2022-04-27 10:33:22.639 DBG audio: Creating Output audio device: “” , bits 8 , codec 64 , latency 150 , localAFGain 255 , radioChan 1 , resampleQuality 4 , samplerate 48000 , uLaw false
2022-04-27 10:33:22.639 DBG audio: Output setVolume: 255 ( 1 )
2022-04-27 10:33:22.639 DBG audio: Output Preferred Format: SampleSize 16 Channel Count 2 Sample Rate 44100 Codec “audio/pcm” Sample Type SignedInt
2022-04-27 10:33:22.639 INF audio: Output Internal: sample rate 44100 channel count 2
2022-04-27 10:33:22.639 INF audio: Creating opus decoder: success
2022-04-27 10:33:22.639 INF audio: Output wf_resampler_init() returned: 0 resampleRatio: 0.91875
2022-04-27 10:33:22.639 INF audio: Output thread id 0x3fc0
2022-04-27 10:33:22.639 INF audio: Output start() running
2022-04-27 10:33:22.655 INF udp: udpAudio : Received I am here
2022-04-27 10:33:22.670 INF udp: udpCivData : Received I am here
2022-04-27 10:33:24.633 INF udp: CIV Watchdog: no CIV data received for 2s, requesting data start.
2022-04-27 10:33:24.665 INF udp: Audio Watchdog: no audio data received for 2s, restart required?
Thanks for the help.
Simone IU3QEZ
