Installation on Ubuntu 21.04
Hi all, I tried to install wfview on ubuntu 21.04 and when I try to give the command: sudo apt install libqcustomplot2.0 libQt5Multimedia libqt5serialport5 gives me error libqt5serialport5 library not found, the same thing with the command sudo ln -s / usr / lib /x86_64-linux-gnu/libqcustomplot.so.2.0.1 /usr/lib/x86_64-linux-gnu/libqcustomplot.so.2, any suggestions?
Antonio,
I see two problems. I see you can’t find a required library – I’ll check if I have mistyped the name there.
secondly – I am not sure – some package managers don’t install anything if an error occurs and the softlink itself definitely fails if libqcustomplot2.0
is not installed. So I’ll spin up an ubuntu 21.04 image and let you know.
can you in the mean time do a separate:
sudo apt install libQt5Multimedia
If these work, can you redo the softlink command without the spaces:
ln -s /usr/ lib/x86_64-linux-gnu/libqcustomplot.so.2.0.1 /usr/lib/x86_64-linux-gnu/libqcustomplot.so.2
Roeland
Hi Roeland , I have already tried to give single commands
libqcustomplot2.0 installs it without problems while for the libQt5Multimedia package it always gives me the error.
Antonio
Hi Antonio,
I may be way ‘off base’ with this but I thought the package was called libqt5multimedia5 (all lower case)?
sudo apt install libqt5multimedia5
Hi Antonio,
Could you please tell us the output of this command:
apt-cache search serial | grep qt
It may help us find the exact package name.
–Elliott
ok. I’ll redo the 2104 install ina vm and copy/paste what I wrote. Given me 30 minutes and I can confirm
the issue – hopefully with the fix.
I’m at work right now, I’ll let you know when I get home.
UBUNTU:
Hi all, I am trying to install the software on Ubuntu Mate 20.04.2 but when I give the command:
sudo ln -s /usr/lib/x86_64-linux-gnu/libqcustomplot.so.2.0.1 /usr/lib/x86_64-linux-gnu/libqcustomplot.so.2
tells me that the package cannot be found, suggestions?
thaks for the report. I recall I messed up the install instructions.
Can you tell me if the installing of the packages work? I know that some package managers will not install anything if there is a single package not found. So let’s split into three installs:
sudo apt install libqt5serialport5
sudo ln -s /usr/lib/x86_64-linux-gnu/libqcustomplot.so.2.0.1 /usr/lib/x86_64-linux-nu/libqcustomplot.so.2
(that’s a single line)
start wfview
can you specify where it fails? Eventually copy/paste the whole text.
fails with this line
This is the error:
ln: failed to create symbolic link ‘/usr/lib/x86_64-linux-nu/libqcustomplot.so.2’: No such file or directory
iz2twx@iz2twx-desktop:~/dist$
Hi Antonio,
Sometimes the filename is slightly different. Can you try this to help narrow it down:
ls -l /usr/lib/x86_64-linux-gnu/customplot
ls: cannot access ‘/usr/lib/x86_64-linux-gnu/customplot’: No such file or directory
It looks like libqcustomplot isinstalled in a strange place? OK try this command:
find /usr/lib -name "libqcustomplot*" -print
iz2twx@iz2twx-desktop:~/dist$ find /usr/lib -name “libqcustomplot*” -print
/usr/lib/aarch64-linux-gnu/libqcustomplot.so.2.0
/usr/lib/aarch64-linux-gnu/libqcustomplot.so.2.0.1
ok. you can now modify the link yourself with the right paths. something like
sudo ln -s /usr/lib/aarch64-linux-gnu/libqcustomplot.so.2.0.1 /usr/lib/aarch64-linux-gnu/libqcustomplot.so.2
by the way. my ubuntu 21.04:
roeland@ubuntu:~$ cat /etc/release
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=21.04
DISTRIB_CODENAME=hirsute
DISTRIB_DESCRIPTION=“Ubuntu 21.04”
NAME=“Ubuntu”
VERSION=“21.04 (Hirsute Hippo)”
ID=ubuntu
ID_LIKE=debian
PRETTY_NAME=“Ubuntu 21.04”
VERSION_ID=“21.04”
HOME_URL=“https://www.ubuntu.com/
SUPPORT_URL=“https://help.ubuntu.com/
BUG_REPORT_URL=“https://bugs.launchpad.net/ubuntu/
PRIVACY_POLICY_URL=“https://www.ubuntu.com/legal/terms-and-policies/privacy-policy
VERSION_CODENAME=hirsute
UBUNTU_CODENAME=hirsute
and:
roeland@ubuntu:~$ locate libqcustomplot.so.2
weird that we differ here
Just fyi - I had the same identical issue with Mint 20.1. Correcting the path/filename fixed it. Thanks.
Hi, It depends maybe on whether you use 20.04 as update or fresh install.
I had the same issue and found that the line given for Debian 11 contains the right path for Mint 20.1 to create the symlink.
73 and keep up the good work!
Peter - PA0PJE
