Hi Phil,
Thanks. I went through all the steps to connect to the WiFi, and had all correct until step 13, where I needed to set the MOD INPUT of DATA OFF MOD and DATA MOD to WLAN. Did that, turned off IC-705, turned back on, and all settings seem OK. I see the Wi-fi icon on the IC-705 and all seems in order. Unfortunately, I am still getting the same message about CI-V. Note I am using the default CI-V address (a4h), and have transceive set to ON, but not sure that matters. Also, I am using the DHCP address (that responds to a ping) for the IP address (also tried the name IC-705 and the IP address on the IC-705 to no avail). I tried with & without virtual COM5 port set.
Finally, I tried to turn off McAfee firewall, but seems like I am not allowed to do that. This is the only thing that seems left to be an issue. The last log file after the MOD INPUT changes to WLAN are as follows:
2022-05-20 13:01:55.299 INF system: “Starting wfview: build ea09647 on Jul 26 2021 at 11:23:33 by build@wfview.org”
2022-05-20 13:01:55.299 INF system: “Operating System: Windows 10 Version 2009 (i386)”
2022-05-20 13:01:55.299 INF system: “Build Qt Version 5.15.2. Current Qt Version: 5.15.2”
2022-05-20 13:01:56.333 INF default: setState 1
2022-05-20 13:01:56.333 INF default: setState 0
2022-05-20 13:01:57.082 INF system: Loading settings from \HKEY_CURRENT_USER\Software\wfview\wfview
2022-05-20 13:01:57.160 INF gui: Got Audio Output: “”
2022-05-20 13:01:57.160 INF gui: Got Audio Input: “”
2022-05-20 13:01:57.170 INF default: Getting server config
2022-05-20 13:01:57.252 INF system: Cannot prepare WF view without rigCaps. Waiting on this.
2022-05-20 13:01:57.252 INF udp: Starting udpHandler user: “Steve1” rx latency: 332 tx latency: 331 rx sample rate: 48000 rx codec: 4 tx sample rate: 48000 tx codec: 4
2022-05-20 13:01:57.268 INF udp: UDP Stream bound to local port: 55643 remote port: 50001
2022-05-20 13:01:57.315 INF system: Received CommReady!!
Thanks & take care,
Steve
