I am using Wfview 1.63 on Rasperry Pi server and client for a remote setup for an IC 7300 over a fiber connection. This works nicely, but after switching the transceiver off from the client, and then switching on the next day, the waterfall or the audio, or both, does not appear on the client side. I know that the 7300 is beeing switched on, as I also have a linear amp that is switched on by the 7300, and that indicates that the 7300 is indeed switched on.
The cure for this is rebooting the server Pi, which I can do remotely by the command sudo reboot. But it would be better if I understood what is causing the audio/waterfall to not appear after switching the transceiver off and then on remotely. The indication for received bytes is ticking on as it should on the client side, but the audio/waterfall does not start, if I don´t reboot the server Pi.
This is exactly it. The USB device has to be re-opened and if the device name has changed then wfview cannot find it. udev is your friend as documented on our website.
Thanks, I will try the last suggestion and report back.
I am not sure what persistent USB devices are. I do have USB connections to the 7300 and to the linear amplifier. They are assigned different USB ports randomly on the Pi after reboot, but wfview seems to find the 7300 anyway after reboot.
Copy and paste from your exempel above for the 7300, I just substituted the serial no for my device, and the symlink name IC7300. Everything by copy and paste to not mess it up.
IC7300 is listed as a device pointing to a USB port as I showed above. But it not shown as an available device in Wfview.
Yes, and there comes my problem. AUTO, dev/ttyUSB0 and dev/ttyUSB1 is avaiable as serial connection choices, but dev/IC7300 is not visable as a choice.
