I read through all the similar topics and after verifying all the setting variations and I still cannot get any audio to the IC-705 (v.1.32). Every other function works. I am linking it through my wifi network. I haven’t tried the IC-705 Access Point service yet. Although, after playing with the WFview controls I managed to get it transmitting with a strange wide-band modulation signal (monitoring it on another radio). I had to reset the 705 to get it back to normal modulation (USB). It works normally with USB control on a pc (Windows 10)
My setup is:
iMac 12.6.5 Monterey
Wsjt-x 2.6.1
Wfview 1.62
BlackHole 2ch
I would also like to run it on my Mac Laptop (10.11.6 El Capitan) but it is not supported by Wfview. Is there another option or workaround?
Any ideas? Otherwise I will probably give up on Wfview.
Thanks for your response. My wifi router is right next to the computer and radio (1g Fios). I also have an ethernet connection, so I went to that on the mac for this run. I closed everything and restarted them, with the same issue. Here is the log:
Not really, wfview contains 3 different audio systems, designed to overcome this kind of problem. As wfview is developed for Windows/Mac/Linux simultaneously, this was necessary as no one system will be the best choice for all users.
OK, I don’t know if I have to reset anything between the changes but it didn’t make any difference by just selecting the options and reconnecting to the radio.
It did, it would have completely changed the way that audio is processed internally. Have you tried other inputs, maybe try the Microphone to start? I have never used Blackhole but if you only have a 2 channel version that will be routing the output audio to the input, which isn’t a good thing! Input and Output should always go to separate audio devices.
I tried lots of combinations but, so far, no TX audio. I may have to try resetting the radio and output audio settings in different combinations to find a possible solution. Time for a dinner break. Thanks again for your help.
I monitor the Meter functions (including ALC,power,SWR) and there is no indication on them for transmitting or audio. I also monitor power output on an external SWR/Power meter. I also listen on another radio and do not hear anything from the 705. I have the MOD input set to WLAN.
That’s not what Elliott said, in settings you can turn on secondary metering, select TXRXMetering. This is a specific meter that monitors the wfview audio input.
