As the moderators prefer a separate thread by machine type, I have created this one for WFServer on X6200 and WFView on Windows 11.
I suggest you also read the thread at Sounds drops out in Windows 11 connected to the Xiegu X6100
Which covers similar problems with WFView on Windows 11 accessing the X6100.
The X6200 is a different radio from the 6100 in several ways. One point is that its WiFi connectivity is improved, and a stable connection to the WLAN is possible. Unfortunately, it appears to suffer similar issues with WFView audio dropping out, as seen with the X6100.
I have seen on this forum that the least load, most reliability, and least dropouts can be achieved using the Opus codec and setting the latency slider to maximum.
One question from my side is about the compatibility of versions. There are 32-bit and 64-bit versions for Windows in v 1.64 and a 64-bit version of WFview in version 2.03. Of these, running v1.64/X86 appears to be the most responsive on my Windows 11 (64-bit) installation - but what version of the WFServer on the X6200 should be used with each of the clients? Perhaps the embedded WFServer in the X6200 needs an upgrade?
27-02-2025 So far, using my updated custom, X6200 rig file, while extending the time before the audio stream stops, has not cured the problem. Packet loss is still occurring over WiFi. Even temporarily disabling the scope data (one of the largest network loads I would expect) only extends the time before the non-recoverable break. I have tried different codecs, some seem better than others but none so far have been able to recover after losing UDP packets.
Today, Amazon should deliver my USBC-Ethernet adapter. If Audio is stable via that route, it would be proof that the issue lies with the limitation of network bandwidth via my WiFi network.
I will update here most likely only tomorrow as amazon deliver here in the evening normally.
Having switched to a cable connection rather than WiFi, the Ping time is down from 60+ mS to 1mS and the missed packet errors have disappeared in the WFView log.
However, despite various combinations of audio CODEC, sample rate etc, the best I can achieve is about 15-20 seconds of audio before it stops.
Looking at the log, it appears the last actions are the periodic ones and there is one related to a CW sidetone. I am using SSB, so why should something be happening with a CW sidetone?
The log is included below. I am going to see if I have anything around CW sidetone in my rig file and remove it if I have.
Ed DD5LP.
UPDATE: reading the online manual pages, the CW sidetone (ie CW operation via WFView) is not yet implemented, it is only under development - if so why is a reference made to it in my log file? Is it possible some of the new code is in the v 2.0.3 build?
Here’s the log:
2025-02-27 14:05:03.744 INF rig: creating instance of icomCommander()
2025-02-27 14:05:03.744 INF udp: Starting udpHandler user: "user" rx latency: 150 tx latency: 150 rx sample rate: 8000 rx codec: 4 tx sample rate: 8000 tx codec: 4
2025-02-27 14:05:03.744 INF udp: UDP Stream bound to local port: 57482 remote port: 50001
2025-02-27 14:05:04.233 INF udp: udpHandler : Received I am here from: "::ffff:192.168.1.180"
2025-02-27 14:05:04.233 INF udp: udpHandler : Received I am ready
2025-02-27 14:05:04.233 INF udp: udpHandler : Sending login packet
2025-02-27 14:05:04.233 INF udp: Got connection type: "WFVIEW"
2025-02-27 14:05:04.233 INF udp: udpHandler : Received matching token response to our request
2025-02-27 14:05:04.233 INF udp: udpHandler : Detected connection speed WFVIEW
2025-02-27 14:05:04.249 INF udp: udpHandler "Received radio capabilities, Name: X6200, Audio: ICOM_VAUDIO, CIV: a4, MAC: 00:90:c7:36:34:3a CAPF: 5001"
2025-02-27 14:05:04.249 INF udp: Got Connection status for: X6200 Busy: 0 Computer IP "0.0.0.0"
2025-02-27 14:05:04.249 INF udp: Got Radio 0
2025-02-27 14:05:04.249 INF udp: Find available local ports
2025-02-27 14:05:04.249 INF default: Received serial port baud rate from remote server: 115200
2025-02-27 14:05:04.249 INF default: Changing queue interval to 100 ms
2025-02-27 14:05:04.249 INF system: Delay command interval timing: 100 ms
2025-02-27 14:05:04.249 INF udp: Starting udpCivData
2025-02-27 14:05:04.249 INF udp: UDP Stream bound to local port: 57483 remote port: 50002
2025-02-27 14:05:04.249 INF udp: Starting udpAudio
2025-02-27 14:05:04.249 INF udp: UDP Stream bound to local port: 57484 remote port: 50003
2025-02-27 14:05:04.249 INF udp: udpHandler Got serial and audio request success, device name: "X6200"
2025-02-27 14:05:04.249 INF udp: Got Connection status for: X6200 Busy: 1 Computer LENOVO-T-wfview IP "192.168.1.149"
2025-02-27 14:05:04.249 INF audio: Output audio handler starting: "Speaker/HP (Realtek High Definition Audio)"
2025-02-27 14:05:04.249 INF audio: Input audio handler starting: "Microphone Array (Realtek High Definition Audio)"
2025-02-27 14:05:04.249 INF audio: Output thread id 0x47f0
2025-02-27 14:05:04.249 INF audio: Output start() running
2025-02-27 14:05:04.249 INF audio: Input thread id 0x2020
2025-02-27 14:05:04.249 INF audio: Input start() running
2025-02-27 14:05:04.249 INF audioconverter: Starting audioConverter() Input: 1 Channels of 0 8000 Int16 Output: 2 Channels of 0 48000 Float
2025-02-27 14:05:04.249 INF audioconverter: Starting audioConverter() Input: 2 Channels of 0 48000 Float Output: 1 Channels of 0 8000 Int16
2025-02-27 14:05:04.249 INF audioconverter: wf_resampler_init() returned: 0 resampleRatio: 6
2025-02-27 14:05:04.249 INF audioconverter: wf_resampler_init() returned: 0 resampleRatio: 0.166667
2025-02-27 14:05:04.264 INF udp: udpCivData : Received I am here
2025-02-27 14:05:04.264 INF udp: udpAudio : Received I am here
2025-02-27 14:05:04.280 INF rig: "Have new rig ID: 0xa4"
2025-02-27 14:05:04.280 WRN system: Data received before we have rigCaps(), aborting
2025-02-27 14:05:04.296 INF rig: "Loading Rig: X-6200 from C:/Users/edurrant/AppData/Roaming/wfview/wfview/rigs/X-6200.rig"
2025-02-27 14:05:04.296 INF serial: Got rigcaps for: "X-6200"
2025-02-27 14:05:04.296 INF default: Receiving rigcaps into repeater setup.
2025-02-27 14:05:04.296 INF default: repeaterSetup got rigcaps for: "X-6200"
2025-02-27 14:05:04.296 INF rig: Using incomingCIVAddr: (int): 164 hex: "0xa4"
2025-02-27 14:05:04.296 INF system: Running configureVFOs()
2025-02-27 14:05:04.340 INF udp: udpHandler Got new radio time: ( 50707822 ) QTime(14:05:07.822) Offset: -3482 Calc time: QTime(Invalid)
2025-02-27 14:05:04.364 INF udp: udpCivData Got new radio time: ( 50707845 ) QTime(14:05:07.845) Offset: -3481 Calc time: QTime(Invalid)
2025-02-27 14:05:04.478 INF cw: Starting sidetone. Thread= 0x1058
2025-02-27 14:05:04.479 INF cw: Sidetone init() Thread= 0x32a8
2025-02-27 14:05:04.480 INF default: Changing queue interval to 100 ms
2025-02-27 14:05:04.480 INF system: Delay command interval timing: 100 ms
2025-02-27 14:05:04.480 INF system: Start periodic commands (and delete unsupported)
2025-02-27 14:05:04.487 INF cw: "Sidetone Output: Speaker/HP (Realtek High Definition Audio) (volume: 0 rate: 44100 type: 2"
2025-02-27 14:05:04.736 INF udp: udpAudio Got new radio time: ( 50708218 ) QTime(14:05:08.218) Offset: -3482 Calc time: QTime(Invalid)
2025-02-27 14:05:25.141 INF audioconverter: Closing audioConverter() Input: 1 Channels of 0 8000 Int16 Output: 2 Channels of 0 48000 Float
2025-02-27 14:05:25.147 INF audioconverter: Closing audioConverter() Input: 2 Channels of 0 48000 Float Output: 1 Channels of 0 8000 Int16
2025-02-27 14:05:25.148 INF udp: Closing UDP stream : "192.168.1.180" : 50003
2025-02-27 14:05:25.148 INF udp: Closing UDP stream : "192.168.1.180" : 50002
2025-02-27 14:05:25.148 INF udp: Sending token removal packet
2025-02-27 14:05:25.148 INF udp: Closing UDP stream : "192.168.1.180" : 50001
2025-02-27 14:05:25.148 INF rig: closing instance of icomCommander()
2025-02-27 14:05:25.148 INF rig: closing instance of rigCommander()
2025-02-27 14:05:25.148 INF cw: cwSidetone() finished
2025-02-27 14:05:25.163 INF default: Receiving rigcaps into repeater setup.
2025-02-27 14:05:28.662 INF system: Saving settings to "\\HKEY_CURRENT_USER\\Software\\wfview\\wfview"
Edit: Added three back ticks (" ` ") before and after the log text for formatting clarity.
Further Update,
Switching back to version 1.64 of WFView the audio lasts a lot longer (minutes) before breaking however I am unable to use my modified rig file with this version of the program and I think we should try to get everything working on the current version of WFView not an old one.
Thanks, Elliot, so I don’t need to worry about the CW sidetone lines in the log, in that case.
What I have found with the uLaw 8 bit, the audio can run up until almost a minute and what is more interesting is that when the audio drops if I then connect again, it’s only there for a short time but disconnect and reconnect another two times and I have the audio for over 55 seconds again. Unfortunately, I don’t now see any errors in the log which would explain why the audio streaming stops.
However what about the “invalid Qtime” in this section of the log?
2025-02-27 20:10:33.330 INF udp: udpAudio Got new radio time: ( 72637545 ) QTime(20:10:37.545) Offset: -4215 Calc time: **QTime(Invalid)**
2025-02-27 20:11:05.341 INF udp: Audio Watchdog: no audio data received for 30s, restart required? last: QTime("20:10:34.886")
2025-02-27 20:11:05.341 INF audioconverter: Closing audioConverter() Input: 1 Channels of 1 8000 Int16 Output: 2 Channels of 0 48000 Float
2025-02-27 20:11:05.352 INF audioconverter: Closing audioConverter() Input: 2 Channels of 0 48000 Float Output: 1 Channels of 1 8000 Int1
The audio ran for about 3 seconds before dropping - so perhaps the watchdog has an issue when the Qtime is not available?
73 Ed.
Edit: Added three back tick marks to the beginning and end of the log text for formatting clarity.
OK, no need to worry about the first Qtime not being there.
I have downloaded your very latest exe file and run that instead of v 2.03 and it seems better and in case I have messed something up I decided to take my modified rig file out of the equation and ran with the standard IC705 rig file. The audio streaming stopping result was the same if a little longer - here is the log of two audio interruptions. I now have an invalid command 1A05 - which checking the IC705 handbook is Tone control - which as far as I have tested, the X6200 doesn’t support - hence the error message.But… WFView says it received it from the rig, perhaps the error should say invalid response to 1A05 received from rig?
The two WRN messages did not come up when using the standard v 2.0.3 (and those functions are defined in the rig file) - I guess this is something to do with the latest code changes ? In any case it is not what is stopping the audio streaming.
2025-02-27 20:19:04.885 INF system: wfview version: 2.04 (Git:28459f7 on Feb 24 2025 at 05:05:45 by eliggett@builder)
2025-02-27 20:19:04.885 INF system: Operating System: Windows 11 Version 23H2 (x86_64)
2025-02-27 20:19:04.885 INF system: Looking for External Dependencies:
2025-02-27 20:19:04.885 INF system: QT Runtime Version: 6.8.1
2025-02-27 20:19:04.885 WRN system: QT Build Version Mismatch: 6.3.2
2025-02-27 20:19:04.885 INF system: OPUS Version: libopus 1.5.1-19-g95dbea83
2025-02-27 20:19:04.886 INF system: HIDAPI Version: 0.14.0
2025-02-27 20:19:04.886 INF system: EIGEN Version: 3.4.90
2025-02-27 20:19:04.887 INF system: QCUSTOMPLOT Version: 2.1.1
2025-02-27 20:19:04.887 INF system: RTAUDIO Version: 6.0.1
2025-02-27 20:19:04.887 INF system: PORTAUDIO Version: PortAudio V19.7.0-devel, revision unknown
2025-02-27 20:19:04.889 INF default: Starting caching queue handler thread (ThreadId: 0x1560 )
2025-02-27 20:19:04.930 INF system: Loading settings from "\\HKEY_CURRENT_USER\\Software\\wfview\\wfview"
2025-02-27 20:19:05.015 INF gui: Got Audio Output from Settings: "Speaker/HP (Realtek High Definition Audio)"
2025-02-27 20:19:05.016 INF gui: Got Audio Input from Settings: "Microphone Array (Realtek High Definition Audio)"
2025-02-27 20:19:05.024 INF default: tciServer() listening on 50001
2025-02-27 20:19:05.119 INF audio: PortAudio version: PortAudio V19.7.0-devel, revision unknown
2025-02-27 20:19:05.119 INF audio: Pa_CountDevices returned 27 audio device(s) (*=default)
2025-02-27 20:19:05.119 INF audio: ( 0 ) Input Device : "Microsoft Sound Mapper - Input"
2025-02-27 20:19:05.119 INF audio: * ( 1 ) Input Device : "Microphone (2- USB Audio Device"
2025-02-27 20:19:05.119 INF audio: ( 2 ) Input Device : "Microphone (Logi C270 HD WebCam"
2025-02-27 20:19:05.119 INF audio: ( 3 ) Input Device : "Microphone Array (Realtek High "
2025-02-27 20:19:05.119 INF audio: ( 4 ) Output Device : "Microsoft Sound Mapper - Output"
2025-02-27 20:19:05.119 INF audio: * ( 5 ) Output Device : "Speaker/HP (Realtek High Defini"
2025-02-27 20:19:05.119 INF audio: ( 6 ) Output Device : "Speakers (2- USB Audio Device)"
2025-02-27 20:19:05.119 INF audio: ( 7 ) Output Device : "Speakers (2- USB Audio Device)"
2025-02-27 20:19:05.119 INF audio: ( 8 ) Output Device : "Speaker/HP (Realtek High Definition Audio)"
2025-02-27 20:19:05.120 INF audio: ( 9 ) Input Device : "Microphone (2- USB Audio Device)"
2025-02-27 20:19:05.120 INF audio: ( 10 ) Input Device : "Microphone (Logi C270 HD WebCam)"
2025-02-27 20:19:05.120 INF audio: ( 11 ) Input Device : "Microphone Array (Realtek High Definition Audio)"
2025-02-27 20:19:05.120 INF audio: ( 12 ) Input Device : "Speakers (2- USB Audio Device) [Loopback]"
2025-02-27 20:19:05.120 INF audio: ( 13 ) Input Device : "Speaker/HP (Realtek High Definition Audio) [Loopback]"
2025-02-27 20:19:05.120 INF audio: ( 14 ) Input Device : "Microphone (Logi C270 HD WebCam)"
2025-02-27 20:19:05.120 INF audio: ( 15 ) Output Device : "Telephone ()"
2025-02-27 20:19:05.120 INF audio: ( 16 ) Output Device : "Headphones ()"
2025-02-27 20:19:05.120 INF audio: ( 17 ) Output Device : "Headphones ()"
2025-02-27 20:19:05.120 INF audio: ( 18 ) Input Device : "Microphone Array (Realtek HD Audio Mic input)"
2025-02-27 20:19:05.120 INF audio: ( 19 ) Output Device : "Speakers (Realtek HD Audio output)"
2025-02-27 20:19:05.120 INF audio: ( 20 ) Input Device : "Headset (Bluetooth Hands-Free Wave)"
2025-02-27 20:19:05.120 INF audio: ( 21 ) Output Device : "Headset (Bluetooth Hands-Free Wave)"
2025-02-27 20:19:05.120 INF audio: ( 22 ) Output Device : "Speakers (USB Audio Device)"
2025-02-27 20:19:05.120 INF audio: ( 23 ) Input Device : "Microphone (USB Audio Device)"
2025-02-27 20:19:05.120 INF audio: ( 24 ) Input Device : "Input ()"
2025-02-27 20:19:05.120 INF audio: ( 25 ) Input Device : "Headset (Bluetooth Hands-Free Wave)"
2025-02-27 20:19:05.121 INF audio: ( 26 ) Output Device : "Headset (Bluetooth Hands-Free Wave)"
2025-02-27 20:19:05.121 INF default: Looking for inputs
2025-02-27 20:19:05.123 INF default: Looking for outputs
2025-02-27 20:19:05.125 INF default: Searching for radios with Manufacturer = 0
2025-02-27 20:19:05.337 INF default: Setting color Preset 0 name "Dark"
2025-02-27 20:19:05.436 INF audio: "Client Audio input device Microphone Array (Realtek High Definition Audio) found! "
2025-02-27 20:19:05.437 INF audio: "Client Audio output device Speaker/HP (Realtek High Definition Audio) found! "
2025-02-27 20:19:05.449 INF default: Changing queue interval to 250 ms
2025-02-27 20:19:05.451 INF rig: creating instance of rigCommander()
2025-02-27 20:19:05.451 INF rig: creating instance of icomCommander()
2025-02-27 20:19:05.451 INF cluster: starting dxClusterClient()
2025-02-27 20:19:05.454 INF udp: Starting udpHandler user: "user" rx latency: 500 tx latency: 500 rx sample rate: 8000 rx codec: 1 tx sample rate: 8000 tx codec: 1
2025-02-27 20:19:05.459 INF udp: UDP Stream bound to local port: 56514 remote port: 50001
2025-02-27 20:19:05.562 INF system: Skipping automatic CIV, using user-supplied value of 164
2025-02-27 20:19:05.971 INF udp: udpHandler : Received I am here from: "::ffff:192.168.1.180"
2025-02-27 20:19:05.971 INF udp: udpHandler : Received I am ready
2025-02-27 20:19:05.971 INF udp: udpHandler : Sending login packet
2025-02-27 20:19:05.971 INF udp: Got connection type: "WFVIEW"
2025-02-27 20:19:05.971 INF udp: udpHandler : Received matching token response to our request
2025-02-27 20:19:05.971 INF udp: udpHandler : Detected connection speed WFVIEW
2025-02-27 20:19:05.986 INF udp: udpHandler "Received radio capabilities, Name: X6200, Audio: ICOM_VAUDIO, CIV: a4, MAC: 00:90:c7:36:34:3a CAPF: 5001"
2025-02-27 20:19:05.986 INF udp: Got Connection status for: X6200 Busy: 0 Computer IP "0.0.0.0"
2025-02-27 20:19:05.986 INF udp: Got Radio 0
2025-02-27 20:19:05.986 INF udp: Find available local ports
2025-02-27 20:19:05.986 INF default: Received serial port baud rate from remote server: 115200
2025-02-27 20:19:05.986 INF default: Changing queue interval to 100 ms
2025-02-27 20:19:05.986 INF system: Delay command interval timing: 100 ms
2025-02-27 20:19:05.986 INF udp: Starting udpCivData
2025-02-27 20:19:05.986 INF udp: UDP Stream bound to local port: 56515 remote port: 50002
2025-02-27 20:19:05.986 INF udp: Starting udpAudio
2025-02-27 20:19:05.986 INF udp: UDP Stream bound to local port: 56516 remote port: 50003
2025-02-27 20:19:06.002 INF udp: udpHandler Got serial and audio request success, device name: "X6200"
2025-02-27 20:19:06.002 INF udp: Got Connection status for: X6200 Busy: 1 Computer LENOVO-T-wfview IP "192.168.1.149"
2025-02-27 20:19:06.002 INF audio: Output PortAudio handler starting: "Speaker/HP (Realtek High Definition Audio)"
2025-02-27 20:19:06.002 INF audio: Input PortAudio handler starting: "Microphone Array (Realtek High Definition Audio)"
2025-02-27 20:19:06.002 INF udp: udpCivData : Received I am here
2025-02-27 20:19:06.002 INF audio: Output Chunk size 960
2025-02-27 20:19:06.002 INF audio: Input Chunk size 960
2025-02-27 20:19:06.002 INF udp: udpAudio : Received I am here
2025-02-27 20:19:06.071 INF udp: udpHandler Got new radio time: ( 73150295 ) QTime(20:19:10.295) Offset: -4224 Calc time: QTime(Invalid)
2025-02-27 20:19:06.096 INF udp: udpCivData Got new radio time: ( 73150321 ) QTime(20:19:10.321) Offset: -4225 Calc time: QTime(Invalid)
2025-02-27 20:19:06.191 INF audioconverter: Starting audioConverter() Input: 1 Channels of 1 8000 Int16 Output: 2 Channels of 0 48000 Float
2025-02-27 20:19:06.191 INF audioconverter: wf_resampler_init() returned: 0 resampleRatio: 6
2025-02-27 20:19:06.191 INF audio: Output device successfully opened
2025-02-27 20:19:06.292 INF audioconverter: Starting audioConverter() Input: 2 Channels of 0 48000 Float Output: 1 Channels of 1 8000 Int16
2025-02-27 20:19:06.292 INF audioconverter: wf_resampler_init() returned: 0 resampleRatio: 0.166667
2025-02-27 20:19:06.298 INF audio: Input device successfully opened
2025-02-27 20:19:06.487 INF udp: udpAudio Got new radio time: ( 73150696 ) QTime(20:19:10.696) Offset: -4209 Calc time: QTime(Invalid)
2025-02-27 20:19:07.169 INF rig: "Have new rig ID: 0xa4"
2025-02-27 20:19:07.173 INF rig: "Loading Rig: IC-705 from C:/Program Files/wfview/rigs/IC-705.rig"
2025-02-27 20:19:07.175 WRN rig: **** Function "Read TX Freq" Not Found, rig file may be out of date?
2025-02-27 20:19:07.175 WRN rig: **** Function "CI-V Output" Not Found, rig file may be out of date?
2025-02-27 20:19:07.177 INF serial: Got rigcaps for: "IC-705"
2025-02-27 20:19:07.177 INF rig: Using incomingCIVAddr: (int): 164 hex: "0xa4"
2025-02-27 20:19:07.177 INF default: Receiving rigcaps into repeater setup.
2025-02-27 20:19:07.177 INF default: repeaterSetup got rigcaps for: "IC-705"
2025-02-27 20:19:07.178 INF system: Running configureVFOs()
2025-02-27 20:19:07.276 INF cw: Starting sidetone. Thread= 0x46b4
2025-02-27 20:19:07.277 INF cw: Sidetone init() Thread= 0x3568
2025-02-27 20:19:07.283 INF default: nb max val 1
2025-02-27 20:19:07.283 INF default: nr max val 1
2025-02-27 20:19:07.284 INF cw: "Sidetone Output: Speaker/HP (Realtek High Definition Audio) (volume: 0 rate: 44100 type: 2"
2025-02-27 20:19:07.285 INF default: Changing queue interval to 25 ms
2025-02-27 20:19:07.285 INF system: Delay command interval timing: 25 ms
2025-02-27 20:19:07.285 INF system: Start periodic commands (and delete unsupported)
2025-02-27 20:19:07.576 INF system: receiveMode "Received new mode for Main: 0 (LSB) filter:1 data:0"
2025-02-27 20:19:08.088 INF rig: Unsupported command received from rig "1a0500" Check rig file
2025-02-27 20:19:08.290 INF rig: Unsupported command received from rig "1a0500" Check rig file
2025-02-27 20:19:08.443 INF rig: Unsupported command received from rig "1a0500" Check rig file
2025-02-27 20:19:08.699 INF rig: Unsupported command received from rig "1a0500" Check rig file
2025-02-27 20:19:10.242 INF rig: Unsupported command received from rig "1a0500" Check rig file
2025-02-27 20:19:10.754 INF rig: Unsupported command received from rig "1a0500" Check rig file
2025-02-27 20:19:11.831 INF rig: Unsupported command received from rig "1a0500" Check rig file
2025-02-27 20:19:12.349 INF rig: Unsupported command received from rig "1a0500" Check rig file
2025-02-27 20:19:13.376 INF rig: Unsupported command received from rig "1a0500" Check rig file
2025-02-27 20:19:13.889 INF rig: Unsupported command received from rig "1a0500" Check rig file
2025-02-27 20:19:14.924 INF rig: Unsupported command received from rig "1a0500" Check rig file
2025-02-27 20:19:15.485 INF rig: Unsupported command received from rig "1a0500" Check rig file
2025-02-27 20:19:17.177 INF rig: Unsupported command received from rig "1a0500" Check rig file
2025-02-27 20:19:17.797 INF rig: Unsupported command received from rig "1a0500" Check rig file
2025-02-27 20:19:19.491 INF rig: Unsupported command received from rig "1a0500" Check rig file
2025-02-27 20:19:20.061 INF rig: Unsupported command received from rig "1a0500" Check rig file
2025-02-27 20:19:21.805 INF rig: Unsupported command received from rig "1a0500" Check rig file
2025-02-27 20:19:22.372 INF rig: Unsupported command received from rig "1a0500" Check rig file
2025-02-27 20:19:24.078 INF rig: Unsupported command received from rig "1a0500" Check rig file
2025-02-27 20:19:24.695 INF rig: Unsupported command received from rig "1a0500" Check rig file
2025-02-27 20:19:26.381 INF rig: Unsupported command received from rig "1a0500" Check rig file
2025-02-27 20:19:26.943 INF rig: Unsupported command received from rig "1a0500" Check rig file
2025-02-27 20:19:28.680 INF rig: Unsupported command received from rig "1a0500" Check rig file
2025-02-27 20:19:29.243 INF rig: Unsupported command received from rig "1a0500" Check rig file
2025-02-27 20:19:30.988 INF rig: Unsupported command received from rig "1a0500" Check rig file
2025-02-27 20:19:31.565 INF rig: Unsupported command received from rig "1a0500" Check rig file
2025-02-27 20:19:33.270 INF rig: Unsupported command received from rig "1a0500" Check rig file
2025-02-27 20:19:33.882 INF rig: Unsupported command received from rig "1a0500" Check rig file
2025-02-27 20:19:35.581 INF rig: Unsupported command received from rig "1a0500" Check rig file
2025-02-27 20:19:36.147 INF rig: Unsupported command received from rig "1a0500" Check rig file
2025-02-27 20:19:37.890 INF rig: Unsupported command received from rig "1a0500" Check rig file
2025-02-27 20:19:38.505 INF rig: Unsupported command received from rig "1a0500" Check rig file
2025-02-27 20:19:40.198 INF rig: Unsupported command received from rig "1a0500" Check rig file
2025-02-27 20:19:40.763 INF rig: Unsupported command received from rig "1a0500" Check rig file
2025-02-27 20:19:42.507 INF rig: Unsupported command received from rig "1a0500" Check rig file
2025-02-27 20:19:42.920 INF audioconverter: Closing audioConverter() Input: 1 Channels of 1 8000 Int16 Output: 2 Channels of 0 48000 Float
2025-02-27 20:19:42.931 INF audioconverter: Closing audioConverter() Input: 2 Channels of 0 48000 Float Output: 1 Channels of 1 8000 Int16
2025-02-27 20:19:42.935 INF udp: Closing UDP stream : "192.168.1.180" : 50003
2025-02-27 20:19:42.935 INF udp: Closing UDP stream : "192.168.1.180" : 50002
2025-02-27 20:19:42.935 INF udp: Sending token removal packet
2025-02-27 20:19:42.935 INF udp: Closing UDP stream : "192.168.1.180" : 50001
2025-02-27 20:19:42.935 INF rig: closing instance of icomCommander()
2025-02-27 20:19:42.935 INF rig: closing instance of rigCommander()
2025-02-27 20:19:42.935 INF cw: cwSidetone() finished
2025-02-27 20:19:42.950 INF default: Receiving rigcaps into repeater setup.
2025-02-27 20:19:49.248 INF audio: Audio device(s) found (*=default)
2025-02-27 20:19:49.248 INF audio: * ( 0 ) Input Device : "Microphone (2- USB Audio Device)"
2025-02-27 20:19:49.248 INF audio: ( 1 ) Input Device : "Microphone (Logi C270 HD WebCam)"
2025-02-27 20:19:49.248 INF audio: ( 2 ) Input Device : "Microphone Array (Realtek High Definition Audio)"
2025-02-27 20:19:49.257 INF audio: * ( 0 ) Output Device : "Speaker/HP (Realtek High Definition Audio)"
2025-02-27 20:19:49.257 INF audio: ( 1 ) Output Device : "Speakers (2- USB Audio Device)"
2025-02-27 20:19:49.257 INF default: Looking for inputs
2025-02-27 20:19:49.257 INF default: Looking for outputs
2025-02-27 20:19:58.111 INF rig: creating instance of rigCommander()
2025-02-27 20:19:58.111 INF rig: creating instance of icomCommander()
2025-02-27 20:19:58.111 INF udp: Starting udpHandler user: "user" rx latency: 500 tx latency: 500 rx sample rate: 8000 rx codec: 1 tx sample rate: 8000 tx codec: 1
2025-02-27 20:19:58.111 INF udp: UDP Stream bound to local port: 59202 remote port: 50001
2025-02-27 20:19:58.126 INF system: Skipping automatic CIV, using user-supplied value of 164
2025-02-27 20:19:58.615 INF udp: udpHandler : Received I am here from: "::ffff:192.168.1.180"
2025-02-27 20:19:58.615 INF udp: udpHandler : Received I am ready
2025-02-27 20:19:58.615 INF udp: udpHandler : Sending login packet
2025-02-27 20:19:58.615 INF udp: Got connection type: "WFVIEW"
2025-02-27 20:19:58.615 INF udp: udpHandler : Received matching token response to our request
2025-02-27 20:19:58.615 INF udp: udpHandler : Detected connection speed WFVIEW
2025-02-27 20:19:58.615 INF udp: udpHandler "Received radio capabilities, Name: X6200, Audio: ICOM_VAUDIO, CIV: a4, MAC: 00:90:c7:36:34:3a CAPF: 5001"
2025-02-27 20:19:58.615 INF udp: Got Connection status for: X6200 Busy: 0 Computer IP "0.0.0.0"
2025-02-27 20:19:58.615 INF udp: Got Radio 0
2025-02-27 20:19:58.615 INF udp: Find available local ports
2025-02-27 20:19:58.630 INF default: Received serial port baud rate from remote server: 115200
2025-02-27 20:19:58.630 INF default: Changing queue interval to 100 ms
2025-02-27 20:19:58.630 INF system: Delay command interval timing: 100 ms
2025-02-27 20:19:58.630 INF udp: Starting udpCivData
2025-02-27 20:19:58.630 INF udp: UDP Stream bound to local port: 57773 remote port: 50002
2025-02-27 20:19:58.630 INF udp: Starting udpAudio
2025-02-27 20:19:58.630 INF udp: UDP Stream bound to local port: 57774 remote port: 50003
2025-02-27 20:19:58.630 INF udp: udpHandler Got serial and audio request success, device name: "X6200"
2025-02-27 20:19:58.630 INF udp: Got Connection status for: X6200 Busy: 1 Computer LENOVO-T-wfview IP "192.168.1.149"
2025-02-27 20:19:58.630 INF audio: Output audio handler starting: "Speaker/HP (Realtek High Definition Audio)"
2025-02-27 20:19:58.630 INF audio: Input audio handler starting: "Microphone Array (Realtek High Definition Audio)"
2025-02-27 20:19:58.630 INF udp: udpCivData : Received I am here
2025-02-27 20:19:58.630 INF audio: Output thread id 0x1104
2025-02-27 20:19:58.630 INF audio: Output start() running
2025-02-27 20:19:58.630 INF audioconverter: Starting audioConverter() Input: 1 Channels of 1 8000 Int16 Output: 2 Channels of 0 48000 Float
2025-02-27 20:19:58.630 INF udp: udpAudio : Received I am here
2025-02-27 20:19:58.630 INF audioconverter: wf_resampler_init() returned: 0 resampleRatio: 6
2025-02-27 20:19:58.630 INF audio: Input thread id 0x4458
2025-02-27 20:19:58.630 INF audioconverter: Starting audioConverter() Input: 2 Channels of 0 48000 Float Output: 1 Channels of 1 8000 Int16
2025-02-27 20:19:58.630 INF audio: Input start() running
2025-02-27 20:19:58.630 INF audioconverter: wf_resampler_init() returned: 0 resampleRatio: 0.166667
2025-02-27 20:19:58.708 INF udp: udpHandler Got new radio time: ( 73202930 ) QTime(20:20:02.930) Offset: -4222 Calc time: QTime(Invalid)
2025-02-27 20:19:58.724 INF udp: udpCivData Got new radio time: ( 73202951 ) QTime(20:20:02.951) Offset: -4227 Calc time: QTime(Invalid)
2025-02-27 20:19:59.164 INF udp: udpAudio Got new radio time: ( 73203382 ) QTime(20:20:03.382) Offset: -4218 Calc time: QTime(Invalid)
2025-02-27 20:19:59.315 INF rig: "Have new rig ID: 0xa4"
2025-02-27 20:19:59.320 INF rig: "Loading Rig: IC-705 from C:/Program Files/wfview/rigs/IC-705.rig"
2025-02-27 20:19:59.322 WRN rig: **** Function "Read TX Freq" Not Found, rig file may be out of date?
2025-02-27 20:19:59.322 WRN rig: **** Function "CI-V Output" Not Found, rig file may be out of date?
2025-02-27 20:19:59.324 INF serial: Got rigcaps for: "IC-705"
2025-02-27 20:19:59.324 INF rig: Using incomingCIVAddr: (int): 164 hex: "0xa4"
2025-02-27 20:19:59.324 INF default: Receiving rigcaps into repeater setup.
2025-02-27 20:19:59.324 INF default: repeaterSetup got rigcaps for: "IC-705"
2025-02-27 20:19:59.325 INF system: Running configureVFOs()
2025-02-27 20:19:59.432 INF cw: Starting sidetone. Thread= 0x46b4
2025-02-27 20:19:59.432 INF default: nb max val 1
2025-02-27 20:19:59.432 INF default: nr max val 1
2025-02-27 20:19:59.433 INF cw: Sidetone init() Thread= 0x12d4
2025-02-27 20:19:59.434 INF default: Changing queue interval to 25 ms
2025-02-27 20:19:59.434 INF system: Delay command interval timing: 25 ms
2025-02-27 20:19:59.434 INF system: Start periodic commands (and delete unsupported)
2025-02-27 20:19:59.442 INF cw: "Sidetone Output: Speaker/HP (Realtek High Definition Audio) (volume: 0 rate: 44100 type: 2"
2025-02-27 20:19:59.779 INF system: receiveMode "Received new mode for Main: 0 (LSB) filter:1 data:0"
2025-02-27 20:20:00.291 INF rig: Unsupported command received from rig "1a0500" Check rig file
2025-02-27 20:20:00.292 INF rig: Unsupported command received from rig "1a0500" Check rig file
2025-02-27 20:20:00.551 INF rig: Unsupported command received from rig "1a0500" Check rig file
2025-02-27 20:20:00.811 INF rig: Unsupported command received from rig "1a0500" Check rig file
2025-02-27 20:20:01.111 INF rig: Unsupported command received from rig "1a0500" Check rig file
2025-02-27 20:20:02.657 INF rig: Unsupported command received from rig "1a0500" Check rig file
2025-02-27 20:20:03.188 INF rig: Unsupported command received from rig "1a0500" Check rig file
2025-02-27 20:20:04.201 INF rig: Unsupported command received from rig "1a0500" Check rig file
2025-02-27 20:20:04.761 INF rig: Unsupported command received from rig "1a0500" Check rig file
2025-02-27 20:20:05.787 INF rig: Unsupported command received from rig "1a0500" Check rig file
2025-02-27 20:20:06.302 INF rig: Unsupported command received from rig "1a0500" Check rig file
2025-02-27 20:20:06.456 INF audioconverter: Closing audioConverter() Input: 1 Channels of 1 8000 Int16 Output: 2 Channels of 0 48000 Float
2025-02-27 20:20:06.461 INF audioconverter: Closing audioConverter() Input: 2 Channels of 0 48000 Float Output: 1 Channels of 1 8000 Int16
2025-02-27 20:20:06.463 INF udp: Closing UDP stream : "192.168.1.180" : 50003
2025-02-27 20:20:06.463 INF udp: Closing UDP stream : "192.168.1.180" : 50002
2025-02-27 20:20:06.463 INF udp: Sending token removal packet
2025-02-27 20:20:06.463 INF udp: Closing UDP stream : "192.168.1.180" : 50001
2025-02-27 20:20:06.463 INF rig: closing instance of icomCommander()
2025-02-27 20:20:06.463 INF rig: closing instance of rigCommander()
2025-02-27 20:20:06.463 INF cw: cwSidetone() finished
2025-02-27 20:20:06.478 INF default: Receiving rigcaps into repeater setup.
73 Ed.
Edit: Added three back ticks to format the log text.
