I have a Contour Shuttle V1 that does not appear to be detected. Just wondering if anyone has found a workaround to use it?
All Shuttles (including different branded) are detected here. Which version wfview are you using ?
And BTW, don’t install a driver, wvfiew has its own shuttle-handling you have to setup in wfview first.
1.64. this is the model found. Appears to be for a specific model. WFView did not find it. Installed the contour drivers and if successfully found it.
This one should be detected - have a look at this topic:
https://forum.wfview.org/t/remote-tuning-knobs/2358
The correct procedure is:
connect the shuttle to an USB.port
do NOT run any shuttle drivers, wfview should detect it on its own.
start your wfview-program
go to Settings > External Control
Enable USB-Controllers
Setup USB Controllers to your desires.
