New Debian testing build. WFview, CQRlog, JTDX from Debian repository. After configuring rig control and loop back audio, everything works fine, except this message, about 2 per second: INF rigctld: Unimplememted command “+p”. If I close CQRlog, the message stops, opening CQRlog again, the messages start again. Doesn’t seem to matter if CQRlog rig control settings are configured for WFview or FLRIG.
Otherwise, everything works great, just one Hugh WFview log file after a few hours of operation.
Thanks to all the team members for a great project!
I guess I can’t send a photo, the script fails, just like my old build. Libcustomplot2.0 is not available. Also, there was an termbin log sent to: https://termbin.com/apv15.
That termbin doesn’t exist, so not sure what happened there? I have promoted your account though so you should now be able to post images.
I assume you allowed the build script to install dependencies as libqcustomplot2.0 should be installed by the script. Can you confirm your Debian version?
Then I tried installing answering no to installing dependencies as WFview was already installed from Debian repositories. I will have to try the install again and take photos to send. I don’t have the Debian machine associated with my email, just use for ham radio.
Possibly I type the wrong termbin log address.
WFview 1.60 is scheduled to move to Debian testing in the repository in 4 days. Currently in SID.
I have upgraded the build script to include the correct version of qcustomplot for your system. You can download the buildscript and try again, it may be easier with the script walking you through it.
You can upgrade your build script by running this command in the same directory that you already have your build script (likely ~/Downloads):
If it fails, can you please post the entire output for us to see? I do appreciate your testing; it’s hard to test on every platform and version and we really rely on folks like you to let us know where there are problems.
Please do install dependencies using the build script. Press “Y” when prompted. I believe you are missing the “-dev” package of qcustomplot, and pressing “Y” when asked should install it.
On the other hand, if you did press Y, I am quite curious.
Appreciate your help, however the patch looks a bit over my pay grade!
I am new to Linux, have been able to get by with most things. I think I will just wait 3 more days in hopes that version 1.60 makes it into Debian testing, and there is a fix for my original question with CQRLOG.
