IC-7300. Win 11 64 bits, Does not show on rig
Thanks Phil!!
Thanks worked for me also.
Thank you, that seems to have fixed it!
We are going to re-release 1.60 containing a proper fix for thisâŚ
OK the Windows downloads for 1.60 have been updated with the fix. The waterfall format workaround is perfectly OK to leave in place though.
Thank you very much for the quick fix.
Dear Phil and to the group. A big problem has occurred since 1.60. although client and server 1.60 is installed on both sides, the client immediately gets stuck on my Win 10 PC. everything went ufb up to version 1.59! Everything for the IC 7300 via RPI 4 . with the IC 705, on the other hand, everything works great! Is there a DLL missing or is there still something to be corrected??? canât send a log file!!! Vy 73 Jan-Peter-DL3KVT
Hi Jan-Peter
Does wfview start on the client PC and just âhangâ or does the window never appear? Can you explain âexactlyâ what happens as everything needed to run wfview is definitely packaged with it?
Can you check the %TEMP%/wfview directory as it may have been able to log something before crashing?
Hi Jan-Peter
Hello dear Phil, the problem has been solved! I copied the 1.60 version into a new directory and so it simply generated a wrong IP address and a different password that didnât belong there. in the same folder as before, he always took over everything 1:1! Now everything works great! was just writing to you!!! Vy 73 by Jan-Peter-DL3KVT
Hello, can´t install the version 1.60 on my computer with windows 10 22h2 os 32 bit.
Got the right install file, but don´t let me install.
Version 1.5 works fine for install but I miss the highlights you offer on 1.6.
Gunnar
I have never seen Windows 10 32 bit, to be honest I canât really think of any reason to install it!
Do you get any error messages? It is possible that the installer that I used for the 32bit version has generated a 64bit installer, but I donât have any machines to test it on.
If this is the case, I can probably generate a new installer using an older version.
and what is the error thrown?
I am sure that Phil mentioned highlights
Iâve just checked the changelog for the QT installer framework and it does look like they have moved to a 64 bit installer. Give me a few minutes and I will generate a new 32bit installer.
4.4.0-beta
- Build Windows installer with 64bit MSVC2019 (QTIFW-2544)
Hi Gunnar.
Can you try downloading the 1.60 32bit Windows download again from Windows (x86) release v1.6 | wfview
This âshouldâ now be a 32bit installer.
Thanks Phil,
now it works with the new installer.
So I´m using an older laptop with not to much RAM, thatsway I run 32 bit version on this system.
Thanks for quick support, have a nice sunday!
Gunnar
as windows needs quite a lot of memory, what actually have you there?
thanks for 1.6 juste tested here
PC1 W7-64 connected USB to IC7100
WFview set as server
PC2 W10-64 connected to PC1 WFview client
initial WFview at client showed now the IC7100 at the correct frequency ( IC7100 tuned ay 3630 LSB )
first time i heard audio with this version 1.5 never connected to server and never had audio on PC1 or 2
But the audio was just noise no relation with the audio heard on the IC7100
after some trying audio noise was lost on PC1 and PC2
until now not found why
after that the IC7100 setting was changed by WFview i had to enable mic in âdata off modeâ that was changed
will do some more tests
Installed x64 option on a Windows 10 laptop with no issues. Like the new features.
Many thanks - great job!
Richard
KE7KRF
running 4GB shared with graphics only 3.5 available
for the fun of it I have tested w10, 2G memory and wfview. It does work but⌠thatâs all I can say. Not recommended to anyone. I might strip down the OS some time.
