Ive followed the instruction for this install and all commands are working till I get to “make -j” then it dumps with these errors:
wfmain.o: file not recognized: File truncated
collec2: error: Id returned 1 exit stratus
Makefile:249: recipe for target ‘wfview’ failed
make: *** [wfview] Error 1
Im not a Linux wizard and can get most stuff done. This one has be baffled.
I can try that. I gave up on the OrangePi and now working with a RaspberryPi 4B. Hoping it works this
time. Im not giving up on the OrangePi yet. Its too powerful to ignore
Allen
Well installed Ubuntu 21.04, install went all the way through which I “assumed” (that word again), that it had worked, Even did a reboot after install. But no Icon on Desktop, or anyway to launch that I can see. This version have a very weird desktop and some things dont work like I think they should. Had heck of time finding Terminal so I could input lines of code.
Any ideas why no Icon. Or what file starts the software.?
Allen
The install script (install.sh) will install the program into /usr/local/bin/wfview, and the launcher desktop icon to /usr/share/applications/wfview.desktop.
Please let me know if either of these work for you.
Well trying another build and it worked all the way to the end
few commands:
3. Create a build directory, compile, and install:
mkdir build
cd build
qmake …/wfview/wfview.pro
make -j
sudo ./install.sh
qmake is making the wfview.pro in the directory wfview then make -j doesnt work says “nothing to do”
sudo ./install.sh stalls
It is important to be very precise with the commands. qmake should not be making anything in the source folder (“wfview”). It should make in the “build” folder. Looking at your message there, you do have an extra dot in the qmake line. It should be:
mkdir build
cd build
qmake ../wfview/wfview.pro
make -j
sudo ./install.sh
Wish I could copy from screen to text:
in Documents/build I enter make -j (get this error “make: *** No targets specified and no makefile found. Stop.”
enter sudo ./install.sh (get this error “./install.sh: command not found”
This is where it always gets messed up. Got though all the commands in the INSTALL.md, and these are the last few files. Nothing is being generated to other directories as noted above in Elliots post on this subject.
Allen
pi@WB7SWW:~/Documents/build $ qmake …/wfview/wfview.pro
Project ERROR: Unknown module(s) in QT: multimedia
pi@WB7SWW:~/Documents/build $ ls -a
. … .qmake.stash
NOTE: the …/wfview/wfview.pro files are where they should be. I just did the command to show what happens when you repeat the command. Whats after that is the results of ls -a in build directory.
This is the result of the apt-get installs:
/Documents/build $ sudo apt-get install libqt5multimedia5-plugins
Reading package lists… Done
Building dependency tree
Reading state information… Done
The following additional packages will be installed:
libqt5multimediagsttools5 libqt5multimediaquick5 libqt5multimediawidgets5
libqt5qml5 libqt5quick5
Suggested packages:
qt5-qmltooling-plugins
The following NEW packages will be installed:
libqt5multimedia5-plugins libqt5multimediagsttools5 libqt5multimediaquick5
libqt5multimediawidgets5 libqt5qml5 libqt5quick5
0 upgraded, 6 newly installed, 0 to remove and 0 not upgraded.
Need to get 2,367 kB of archives.
After this operation, 9,564 kB of additional disk space will be used.
Do you want to continue? [Y/n] Y
Get:1 http://mirror.pit.teraswitch.com/raspbian/raspbian buster/main armhf libqt5multimediawidgets5 armhf 5.11.3-2 [35.0 kB]
Get:2 http://mirror.pit.teraswitch.com/raspbian/raspbian buster/main armhf libqt5multimediagsttools5 armhf 5.11.3-2 [64.1 kB]
Get:3 http://mirror.pit.teraswitch.com/raspbian/raspbian buster/main armhf libqt5qml5 armhf 5.11.3-4 [1,001 kB]
Get:4 http://mirror.pit.teraswitch.com/raspbian/raspbian buster/main armhf libqt5quick5 armhf 5.11.3-4 [1,049 kB]
Get:5 http://mirror.pit.teraswitch.com/raspbian/raspbian buster/main armhf libqt5multimediaquick5 armhf 5.11.3-2 [37.9 kB]
Get:6 http://mirror.pit.teraswitch.com/raspbian/raspbian buster/main armhf libqt5multimedia5-plugins armhf 5.11.3-2 [180 kB]
Fetched 2,367 kB in 3s (737 kB/s)
Selecting previously unselected package libqt5multimediawidgets5:armhf.
(Reading database … 102112 files and directories currently installed.)
Preparing to unpack …/0-libqt5multimediawidgets5_5.11.3-2_armhf.deb …
Unpacking libqt5multimediawidgets5:armhf (5.11.3-2) …
Selecting previously unselected package libqt5multimediagsttools5:armhf.
Preparing to unpack …/1-libqt5multimediagsttools5_5.11.3-2_armhf.deb …
Unpacking libqt5multimediagsttools5:armhf (5.11.3-2) …
Selecting previously unselected package libqt5qml5:armhf.
Preparing to unpack …/2-libqt5qml5_5.11.3-4_armhf.deb …
Unpacking libqt5qml5:armhf (5.11.3-4) …
Selecting previously unselected package libqt5quick5:armhf.
Preparing to unpack …/3-libqt5quick5_5.11.3-4_armhf.deb …
Unpacking libqt5quick5:armhf (5.11.3-4) …
Selecting previously unselected package libqt5multimediaquick5:armhf.
Preparing to unpack …/4-libqt5multimediaquick5_5.11.3-2_armhf.deb …
Unpacking libqt5multimediaquick5:armhf (5.11.3-2) …
Selecting previously unselected package libqt5multimedia5-plugins:armhf.
Preparing to unpack …/5-libqt5multimedia5-plugins_5.11.3-2_armhf.deb …
Unpacking libqt5multimedia5-plugins:armhf (5.11.3-2) …
Setting up libqt5qml5:armhf (5.11.3-4) …
Setting up libqt5multimediawidgets5:armhf (5.11.3-2) …
Setting up libqt5multimediagsttools5:armhf (5.11.3-2) …
Setting up libqt5quick5:armhf (5.11.3-4) …
Setting up libqt5multimediaquick5:armhf (5.11.3-2) …
Setting up libqt5multimedia5-plugins:armhf (5.11.3-2) …
Processing triggers for libc-bin (2.28-10+rpi1) …
pi@WB7SWW:~/Documents/build $ make -j
pi@WB7SWW:~/Documents/build $ sudo ./install.sh
sudo: ./install.sh: command not found
and this is the result of ls -a in build directory:
pi@WB7SWW:~ $ cd Documents/build
. … .qmake.stash
This is a good step. I think we found the missing library. However, before you proceed, can you please make sure you ran each line in Step 1 of the INSTALL.md file? Each of those items must be installed in order to build.
Once you’ve run those (and it’s totally fine to run the apt-get stuff more than once just to be sure), remove your build directory entirely, make a new build directory, and continue.
At this point, make sure there aren’t any errors. If there aren’t any, then check with the ls -la command to see if the Makefile was created. If so, continue:
eliggett@chi:~/Documents/dev/wfview-ui-enhance/build$ make -j
It Worked! Did all from 1 to redoing the build directory. All ran with no problems. Ive included the last part of the install including the ./install.sh.
pi@WB7SWW:~/Documents/build $ cd
pi@WB7SWW:~/Documents $
pi@WB7SWW:~/Documents $ ls
build wfview
pi@WB7SWW:~/Documents $ cd build
pi@WB7SWW:~/Documents/build $ sudo $0
root@WB7SWW:/home/pi/Documents/build# sudo ./install.sh
This script copies the following items into your system:
icon: wfview.png to /usr/share/pixmaps/
wfview application to /usr/local/bin/
wfview.desktop to /usr/share/applications/
qdarkstyle stylesheet to /usr/share/wfview/stylesheets
This script MUST be run from the build directory. Do not run it from the source directory!
Do you wish to continue? (Y/N): y
Copying files now.
