Hi Elliott,
I can confirm the IC-736 Menu Settings are as you recommend, excepting Baud Rate was 9600, which I have changed to 1200 as a further test. Obviously, I changed the Baud Rate to 1200 in WFView as well.
Still no joy, I’m afraid!
The Legacy Com 1 Port has never had anything but the Icom IC-736 connected, leaving the usual Windows Port Settings in-place 9600/8/1/N FIFOs enabled etc etc.
There are no Programs Starting at Boot Time that would use Com 1, nor any Services that would use Com 1.
I have an identical machine - unused, running a virgin Win 10 install. I installed WFView on this machine, and hooked the 736 to the Com 1 Port on it - and exactly the same problem. Debug looks like this:
PS C:\Users\Peter.PHASORNET> Get-Content $env:TEMP\wfview.log -Wait -Tail 30
2022-03-10 15:05:25.422 DBG rig: ----- End hex dump -----
2022-03-10 15:05:30.327 DBG rig: Final payload in rig commander to be sent to rig:
2022-03-10 15:05:30.327 DBG rig: ---- Begin hex dump -----:
2022-03-10 15:05:30.327 DBG rig: "INDEX: 00 01 02 03 04 05 "
2022-03-10 15:05:30.327 DBG rig: "DATA: fe fe 40 e1 11 fd "
2022-03-10 15:05:30.327 DBG rig: ----- End hex dump -----
2022-03-10 15:05:35.206 DBG rig: Final payload in rig commander to be sent to rig:
2022-03-10 15:05:35.206 DBG rig: ---- Begin hex dump -----:
2022-03-10 15:05:35.206 DBG rig: "INDEX: 00 01 02 03 04 05 06 "
2022-03-10 15:05:35.206 DBG rig: "DATA: fe fe 40 e1 1c 00 fd "
2022-03-10 15:05:35.206 DBG rig: ----- End hex dump -----
2022-03-10 15:05:35.206 DBG serial: ---- Begin hex dump -----:
2022-03-10 15:05:35.206 DBG serial: "INDEX: 00 01 02 03 04 05 06 07 "
2022-03-10 15:05:35.206 DBG serial: "DATA: fe fe e1 40 1c 00 00 fd "
2022-03-10 15:05:35.206 DBG serial: ----- End hex dump -----
2022-03-10 15:05:35.206 DBG rig: "INDEX: 00 01 02 03 "
2022-03-10 15:05:35.206 DBG rig: "DATA: 1c 00 00 fd "
2022-03-10 15:05:39.083 DBG rig: Final payload in rig commander to be sent to rig:
2022-03-10 15:05:39.083 DBG rig: ---- Begin hex dump -----:
2022-03-10 15:05:39.083 DBG rig: "INDEX: 00 01 02 03 04 05 06 07 08 09 10 "
2022-03-10 15:05:39.083 DBG rig: "DATA: fe fe 40 e1 00 00 68 20 14 00 fd "
2022-03-10 15:05:39.083 DBG rig: ----- End hex dump -----
2022-03-10 15:05:40.056 DBG rig: Final payload in rig commander to be sent to rig:
2022-03-10 15:05:40.056 DBG rig: ---- Begin hex dump -----:
2022-03-10 15:05:40.056 DBG rig: "INDEX: 00 01 02 03 04 05 06 07 08 09 10 "
2022-03-10 15:05:40.056 DBG rig: "DATA: fe fe 40 e1 00 00 55 21 14 00 fd "
2022-03-10 15:05:40.056 DBG rig: ----- End hex dump -----
2022-03-10 15:05:41.929 DBG rig: Closing rig comms
The only thing I can think of is the Icom CT17 Serial to CI-V Converter. However, it’s been operating fine for 20+ years, with many differing Programs, and is just a MAX232 and 5 Volt regulator!
I cannot think of anything else. If I get time one weekend, I’ll knock-up another RS232 – CIV converter as see how that fares. I’ll also try a FTDI USB- COM Adapter, although ultimately I have run out of free COM Ports and would prefer to leave the 736 on Com 1. (If it’s not broke, don’t fix it).
Thanks for all your help – I think that we have run-out of all other options – but I will keep the Forum informed if I find a solution, and/or the results of any further tests.
Regards and best 73
de Peter G6E
