Have just downloaded and installed Wfview on my Windows 10 machine (version 20H2 is build 19042.867) when I try and run the program I get an error message saying that MSVCP140_1.dll was not found. It suggests trying a reinstall but the same error recurs. Can anyone help?
Hi Chris.
If you install the 1.1a test release, this will automatically install the Visual C++ runtime libraries which are required to run wfview (and the cause of the error you are seeing). Alternatively, the vdredist.exe file is also copied to the wfview installation directory so you can install it manually.
Many Thanks Phil, Ill give it a go.
73s
Chris
G1VNA
note that we just released 1.1 (with winstaller)
